Parking brake switch/brake warning light
Birmingham, AL
Hi all, Land Cruiser newbie and proud owner of a "fully restored" 1982 FJ40. I love it and overall is in great shape, but I have learned that "fully restored" does not always mean everything was done correctly. Shortly after I got it, I noticed the brake warning light/seat belt light did not illuminate. I pulled it out of the dash, thinking it might be the bulbs, only to find it wasn't connected to anything. I did some research and found that it should illuminate when the parking brake is engaged. Well, looking at the parking brake switch, it does not appear to be connected to anything either (see pics below)
I have the FSM and though I am not an expert on wiring diagrams, looks to be on same circuit as heater and these should be connected, as well as to the brake warning switch and stop light switch.
My question is: do i just need to directly connect the brake warning light and the parking brake switch, or is there more to it?
Thanks in advance
terms get thrown around frequently and we all have our own definition of them
there is more to the wiring, I think the brake master float also will illuminate the brake light, if the fluid gets low.
any idea who went thru the rig?
I don't know who worked on the truck, I purchased it from a guy in Illinois. It's a US truck. You're right, i think the brake warning switch is attached to the master cylinder and illuminates this light if there is a problem
It's probably disconnected either because they forgot to hook it up during the restoration or they got tired of it just constantly being illuminated unless the parking brake handle is in the exactly perfect position and it will flicker on and off. The other end of the harness it plugs into should be at or just off the top of the wiring harness above your steering column behind your dash
No one knows how these should be wired?
i do know they go bad often and require replacement ?
a simple Continuity Test can help determine if the PIN SWITCH Box is faulty or not ?
if it is , then you have a TOYOTA Genuine parts JAPAN Sourced solution LINK Below ........ :)
The brake light on the dash is grounded by the PB switch, brake fluid reservoir float or the alternator "L" terminal.
Thanks for the replies. the wiring diagram i have (from 1980 FSM) looks a little different - see below - looks like brake warning light and parking brake switch are both grounded through the brake warning switch (which i think i on the master cylinder). But, sounds y'all are telling me there should be a direct connection between the parking brake switch and the warning light on the dash, and that may have been disconnected due to a faulty parking brake switch causing the light to be constantly on? do i have that right? if so, i should be good to go.
That schematic is for a MC equipped with pressure switches, do you have that or the reservoir float switch?
Looks like I do have the float switch, see attached but i guess unsurprisingly, it is not connected to anything either. What year did they change from the pressure switch to the float switch, or could it be either in any year?
Not sure when the change was made. You may have a connector dangling that this connects to. Look around the harness that comes out of the firewall on the driver side.
for some reason I'm thinking the change was 1981? when it went from 2 resevoirs to 1 resevoir
Hi, its kind of late, I bought a 1977 BJ40 a couple of months ago and just went through the same problem. My parking brake light wasn't working. Some hours later, found the wiring issue, but i need a new switch also.
If you have the old style parking brake (on the dash), the light is grounded by the brake warning switch on the master cylinder, and it goes through the brake switch also. Diagram attached.
If you have the "new" style between the seats, you have 2 options, one light for both, grounded by parking brake and/or fluid level switch, or 2 separate lights grounded separately, one by parking brake and the other by fluid level switch. Diagrams attached.
Diagrams attached.
Hope these information helps someone.
Best regards, mery christmas and happy new year to all!!
