Painting - rattle can (need tips)
Fort Worth, TX
have spent years restoring the FJ40. Everything is done. Everything is painted. It was done by a body shop and it’s “prettt good” not “pretty great”
The only thing left to paint are my full doors - I’m ditching the half doors.
Oh did i mention I’m out of money? Can’t send the doors to a shop - too poor to buy a lot of equipment
Is it possible to get a nice, smooth, gloss finish with aerosol cans?
Recommendations and tips appreciated.
There are places to buy premixed aerosol, or you can buy the paint, reducer and hardner and a Preval paint system if you don't have an air compressor and sprayer. Works ok. Preval Pro Pack Kit-0227 - The Home Depot
You'd be better off borrowing a compressor and buying a cheap hvlp gun at Harbor Freight, but the Preval system works ok. Previous owner of my 40 used Preval on the entire car. Paint laid well except for a few spots where he applied to heavy (he also did a poor job masking). Overall, it did a good job for an aerosol sprayer...
www.youtube.com/watch?v=t1nrWz0Ohcg
If you're willing to do some sanding you can paint it with a brush.
Just sand in between coats and the final.
In 2015 I rattle canned mine inside and out. If you have patience, spray paint can work great. Having hvlp painting experience definitely helped me cut down on overspray though. 4 thick coats on everything. Use quality paint and mask everything off carefully for best results. It won't be as scratch resistant as an hvlp paintjob, so get an extra can for future touch ups. Good luck! :cool:
I painted a few cruisers with rattle can and most people are amazed and cannot tell the difference. Like stated above, mask everything and take your time. Temperature plays a big factor. About 70 degrees is perfect.
Here's my most recent rattle can resto...even did the stripes.
Would you recommend sanding to metal? Or just a good scuff from 220 up to 600, feathering any chips.
Primer then wet send, color then wet sand, clear then rubbing compound. Two weeks then wax?
I'm painting the lift gate on my '86 FJ60 this week using aerosol cans from automotivetouchup.com. The passenger fender and valence turned out well, but not spectacular. Take your time sanding and go slow, using finer and finer wet/dry sandpaper, especially when tackling the clear coat. I'm using Rustoleum gloss acrylic lacquer for that. Sand until you get rid of the orange peel, you'll know what that's all about once you get into it.
Put in your Bubba teeth, grab your bib overalls, sand it, and rattle can it!
With any painting, prep is probably just as if not more important.
You don't want to spray color over bare metal, get a self etching primer if you sand that deep. Also get a block to block sand it level. Any dips, divots, imperfections you can see during prep will really stand out in the final.
I like using the hammer finish spray because it hides that kind of stuff, but on doors that isn't what you want.
Lastly, to get good coverage you need a lot of paint.
I spray painted, fully, a first gen MR2 (small car) and in total it took 27 cans to complete in semi gloss black with a clear over. The hood and a couple spots in the doors were thin with black and you could see the spray marks, but turned out pretty well.
I've spray painted some of the 40 we have - when it comes time to fully paint, I will just buy the supplies a d paint with a cheap HVLP - it won't cost much more than the mr2 spray job.
I've rattle canned a bunch of bicycles and most of my first 40. Primer is easy to make smooth, and can be easily sanded. Color is best in gloss without clear coat, and it is slightly harder to not have drips than primer. Smoothness is about planning edges in the process of paint application, because applying several light coats, or painting next to tacky paint isn't as smooth of a result as painting adjacent to truly wet paint. Clear coat is a rattle can disaster, especially evident on flat surfaces; I'm horrible at it. Be aware of paint accumulating on the rattle can orifice, it will cause drips. Same goes for your finger or a nitrile glove. I never sand to prep, but I use green Scotch Brite (to rough-up the surface) and acetone using dish-washing gloves (to remove oily waxy residues). I paint in the cool of morning and bake it in the intense heat of afternoon, so June thru August is the only proper time for a rattle can. I would skip primer unless I have a month of cure time, subsequent layers seem to promote chipping on layers of rattle can paint, particularly where I attatch my bicycle's cable-lock at the seat post, and the vulnerability of the top of the chain stay. Something like a Land Cruiser hood should be ideally painted in a vertical position, from top to bottom. Test your color, technique, and texture on a something like roof flashing. Rattle can mistakes often can be dealt with using acetone without damage to real paint. Don't fret over mistakes, and it is really better to under apply then to over apply. If you find a '73 40, with fuel door, upside down bezel, and hard-top, sporting Rustoleum 'Sand,' factory white fiberglass, and grey primer for a roof liner, that is likely a truck that I once owned.
The SprayMax 2K from 66 autocolor has built in clear-coat. It's expensive, relatively speaking, but also legit.
Lots of good info above. When I rattle bombed mine I used a scotch brite and a bucket of water and some comet cleanser. :hillbilly: I treated the surface rust with rust converter:hillbilly:, I wiped it down with alcohol prior to painting. My truck in no way is a porch puppy so a pretty paint job wasn't my priority. I used Krylon flat khaki and carefully masked. It looked good for a few years, but faded in the Cali. sun. Here's a pic after about a year. (This pic appears in several threads here but here's one more). I was afraid to use a gloss paint in a rattle can for fear of an uneven finish. Semi gloss or flat is more forgiving. I personally wouldn't put a lot of money in a rattle can job.
I think I was only in it about 40 bucks not counting tape etc. I've since re painted with automotive paint for durability.
Believe it or not the little “gun” you attach to the top of the rattle can actually helps a lot! No more sore finger and honestly I didn’t have any splatter using one like I’ve had when using my finger. I was skeptical at first but I’m sold and anytime I rattle can I use it.
there was a good article in hot rod magazine about painting a car with rustoleum and a roller. turned out to be a decent 10 foot paint job. again you pay for it in labor and time: a lot of light coats, wait a day to dry and sanding in between.
On a recent episode of XOR on Power nation, they painted a ford ranger with rattle cans and it came out very nice. They showed some good tips on getting a good outcome.
@Tim71FJ40 I rolled mine.
Like many have said, what you save in $$ you make up for in your labor. I completed 6 'light' coats on my 40, sanding in between. I had both a sanding block and a pneumatic orbital sander in my toolkit. Some coats, I just wanted to thin the paint less and be done with it, but I'm happy with the turnout. It took me about a week as I worked little by little after my 9-5 each day. Take a look at my media albums, have several pics of various stages of paint. I'll include a couple here also. Its a decent job, 10 footer or better depending on where you look.
View media item 66375View media item 66315View media item 66371View media item 66365View media item 66367View media item 66371
