P0430 code 2005 LX470 (1 Viewer)
Atlanta
Recently got my first check engine light... P0430 and P0420 catalytic converter efficiency threshold codes. Read around on mud and most people pointed to new O2 sensors. Took it to two different shops (both specialize in land cruisers) and both quoted me for new cats... 3600 total. I'm at a loss for what to do here. I have some time (luckily did emissions in May) but I want to make sure I consider all of my options before I bite the bullet on this. Any suggestions for a way forward? Thanks
307k on my odo. I was looking for spacers... looks like the rear o2 sensor has flanges that dont allow for most. Do you know where I could find some?
FWIW, my 07 threw a PO420 code last summer. I replaced O2 sensors and did not fix it. Ultimately I read @2001LC s post on spark plugs loosening. Sure enough, one on the driver back had backed out, gas was bypassing it, and my trims were off. Mechanic thought that eventually wrecked the cat. Might not be the issue, but checking fuel trim might help rule out one thing that could damage your cats.
Rock Auto. Purchase the Denso brand.
Edit: Sorry, you want spacers? Maybe buy extra gaskets and stack?
These factory CAT are top shelve and don't just go bad, in first million miles.
So we must find reason, they did, or we kill replacement CATs. Which 98 out of 100 instances, is upstream issue. Number one, issues I've seen in 98-05 4.7L 2UZ-fe, that kills CAT. IS: Bad MAF sensor. These can take out one or both CATs fast. Raw fuel gets inside CAT, igniting and burns them up. But that just one issue. Bottom line, keep your engine well turned.
The 2 out of a 100 not upstream issues. Are typically something like: Flood waters fiil exhaust, sediment contaminating. Or rodents building nest in exhaust, clogging. Or Impact busting CAT material.
