Overland Power (20 Viewers)
Getting ready for COTR. Driving the 200 as a daily this week until we leave have the EcoFlow flow all set up and just running it to see how goes. Well today didn’t go very well. It’s 90+ degrees here in Kansas City and today I let the fridge go with the Delta 2 hooked to it while the truck was parked in a parking lot at work all day. Black truck, hot sun on black asphalt. I probably should’ve realized this wasn’t gonna be a recipe for success essentially the delta 2 shuts itself down if it gets too hot and you can’t charge it or do anything with it until it cools down, which is hard to do when it’s 90°. The good news is the fridge kept running and is still running on its own battery, but if I was camping somewhere without access to Power, I’d be in trouble right now. The fridge is about done and my Delta 2 is at 7% with the temp light blinking. If I were camping, I’d have to hook the fridge to the cigarette lighter of the truck and just turn the truck on to keep the fridge going.
It’s 84° now with a low of like 73 tonight I’m trying to decide if I just let the battery sit in the closed up truck and see how it is in the morning as an experiment or if I should bring the thing inside and cool it down.
Edit: decided to take it into the house to cool it down. Took a while, but eventually the high temp and battery failure lights went out and it’s charging now. I’m very relieved. I was worried I fried it three days before I leave for Colorado.
Am I try to see if I can either borrow or buy 100 W solar panel or something just as a back up. I think the other thing I need to keep in mind is that in my normal Overlanding scenario I would be driving most of the day and I would have the AC running in the truck in which case I wouldn’t probably have overheated the battery. Letting it sit all day in the sun in a parking lot was not a great idea.
We recently ran into the heat problem in spades when we camped at Devil's Garden campground inside Arches National Park. We had daily 100F+ heat, 10-30 mph winds and DUST. We kept the Dometic fridge and the Yeti 1500X cool enough so they would cool and charge when we were driving with air conditioning but if we stopped for a 3 hour hike the interior was blisteting hot. So hot that the Dometic couldn't cool and the Yeti couldn't charge. Also, you couldn't crack the windows or sunroof to vent the heat due to the dust kicked up by the high winds. I was paeticularly worried about dust being sucked into the units by their cooling fans.
So out of desperation I opened 2 windows half way and used blue painters tape to attach and seal cloth hand towels over the openings. This actually worked as the high winds moved a bit of air through the cabin while the cloth towels filtered most of the dust.
I was able to keep the temperature in the cabin down at night simply by cracking the windows as nighttime temperatures went down to the upper 60's and the winds died down which eliminated dust worries.
What I need to get/design for Moab scenarios is a system that takes filtered air from the outside and blows it into the cabin. Bruder trailers of Australia has such a system although it's designed to pressurize the trailer to keep dust out, not cool. Enough air volume would do both.
Have you looked at the window socks they sell on Amazon fairly cheap? They'd probably be a good solution for this provided they filter the dust enough. I have a set, but have yet to have occasion to use them.
This is the one I have, there are tons by many different sellers, i'm sure they are all similar. Maybe a double layer would work with the dust, if one set isn't enough.
Never heard of these. The issue would be dust I think.
The solution just has to be more complicated LOL.
Right now at Mammoth Campground getting 150W from my Merlin XP-170 to my Goal Zero 1500X when in full sun. Best part is the air is cool and unlike Moab, NO DUST so windows can remain open.
Added a 300 wh EcoFlow River to my setup to run loads in the tent while camping. It ran my tent mate’s c-pap machine. It would run down to zero over night and we just charged the next day while driving.
The system worked great for COTR. We left Thursday the 10th and are in Ouray now. I keep the alt charger set at 300 watts and as long as we drive 3 hours or so, we can hit camp with everything charged.
I think the system is pretty good for Colorado camping with moderate temps and trying to park in shaded areas with windows cracked when stopping in towns to explore or eat. For hot weather it may not be enough capacity but don’t like camping in heat anyway.
The Glacier fridge plus the Delta 2 is a total 1324 wh which seems to be enough if driving every day. The River is another 300 wh which is just margin if I don’t have load like a c-pap running overnight. I typically was at 36% on the Delta 2 and still 100% on the Glacier battery when we’d get up in the morning. I could run my induction burned for eggs then hit the road. The only issue we had was sometime the fridges cigarette plug would shake loose and stop charging the fridge.
I need to add some solar to be able to be off parked and off grid for multiple days. Seems like ~250 -300 wh of solar would work out.
500 W alt charger is on sale now for $259. Though I have the 800w charger, I do not see any need to ever charge at that rate. 500 is the max I’ve done and generally 300w is enough for me with 3 hours of driving per day.
Between the smaller gauge wire to run to the unit from the front, and much smaller wire between the charger and battery, this could be significantly better for packaging even though the unit itself isn't any smaller.
It does take up one of the two XT60 ports on the back of the battery though, if that's an issue for anyone.
