Other Suspension Question
Atlanta
I purchased a beautiful 96 LX450 and have been enjoying every minute of it! It came with a 4" lift and 37s KM3s. While it looks cool, it's not practical for our use (98% on road). I'm looking at lowering it to 2-3" lift and 35s on OEM wheels. However, I would consider other options as well. I just need a better understanding of what I currently have, and what could stay and/or work. I've read several threads about upgrading, but not necessarily down sizing.
Currently Installed (from my inspection as no receipts were provided during purchase):
BFGOODRICH® Mud-Terrain T/A KM3 37x12.50R17/D 124Q
Circuit Offroad Steller Matte Gunmetal 17×8.5 6×139.7, -10mm Offset, 4.36 Backspace
2in Wheel Spacers (unable to find brand/link)
OME 419X Front (100mm / 4in)
OME 422X Rear (100mm / 4in)
Radflo OE Replacement 2.5 Front With Remote Reservoir
Fox 2.0 Performance Series Smooth Body IFP Shocks - Rear
Front Radius Arm drop brackets (uncertain if correct brand)
Front & Rear Adjustable Panhard Bar (unable to find brand/link)
Front Swaybar Drop Bracket (unable to find brand/link)
OME Steering Damper
Questions:
What 2-3" springs should I buy? (We will rarely be underload, no plan of future armor)
What equipment will need to be removed when lowering, if any?
Can I remove that 2in Wheel Spacer now and not rub? What about when lowering? (I hate that it's on there, rubs now in reverse on pass side)
If I lower before finding a set of OEM wheels, will the 37s fit without cutting? What about 35s on the current wheels?
Thank you in advance!
I had a 2-1/2" OME setup, bit of a harsh ride though. I am now on a 3.5" Dobinsons lift and 35s with the following:
  • C97-144VT front coils - 3.5"
  • C97-145VT rear coils - 3.5"
  • MRA45-A912 front 4" length shocks for additional travel
  • MRA59-A687 rear 4" length shocks
I only show that so you have some comparison. I am happy with the springs as they are more compliant, definately not harsh. I have not had an opportunity to play with the settings for the shocks yet. I like the springs and would suggest the shorter lengths. You will need to change the shocks if you drop in lift height or you may bend them due to restricted travel length.
I worked with @crikeymike at Exit Off Road but you can also reach out to Dobinsons for help.
i don't think you can remove the backspacers with your current tire/rim combo due to rubbing while turning. I see you have caster correction by way of dropping the front radius arm mounting solution. These will need to come off with lower springs.
If I were you, I'd simply place an ad on classifieds that goes something like this:
i have a 4" suspension and want to trade for your 2" suspension, 37" tires+ rims + wheel spacers plus you throw in xxxx amount of $$$ for my high end shocks/caster correction/etc. I'll need to swap out the both panhard rods and a set of 285 75 16 newish tires on factory rims as well. Oh yeah, this project will be done on both vehicles simultaneously!
This is a $hit ton of work but quite doable on a good weather day outside with beer/weed/pizza ;). For two novices, it'll take two short days or one long day and air tools will make things go quicker.
I'd also connect with your local clubhouse chapter and find some local bros who can help. This makes for a great "tech" day because it'll teach everyone a whole bunch of stuff.
Do you know if the diffs have been regeared for 37s? If so, this is another trade possibility for stock diff ratios.
One thing to keep in mind is that if the new lift is 2" or less, you typically won't need a caster correction solution up front.
This is a lot to take in so PM me if you have ?s. There's a lot of money tied into this suspension!!!
What is it about the ride that you don't like? All terrain tires will be quieter and have a more comfortable ride. Smaller tires will accelerate/decelerate better and effectively lower the gearing. So, just dropping down to 34 or 35" AT tires might make enough of a difference. You could always go with shorter and softer/firmer springs later as a next step depending on how you want to further tune the ride characteristics.
Thank you @Azca, @smorkington, @alia176, and @cts for your responses!
For the questions:
  • The current driving experience is not as good as it should be imo. It's too top heavy and makes turning a two hand performance as well as the immediate decrease in power going up hills. I believe lowering it will assist in the drivability. The KMGs are around 77lbs/e. I think with the right 35 to get me in the 70-67lb range would help too.
  • My measurements on all 4 corners are around 25.5-26in from hub to fender. From my understanding that's around a 5in lift.
  • No it's not regeared.
  • I'm getting a "grrrrr" sound 50mph+ when decelerating/letting off gas. I bet it's from the lift. But the sound is coming from the Tcase from inside the cab. I've been reading the thread about this with a maintenance task for me this weekend.
  • I believe I will keep the current wheels, as they're growing on me. I'm curious if there's spacers due to the fitment to the 80 series. I read that these are for 4runner. And it's been difficult finding some local OEM LX450 wheels haha.
@crikeymike recommended the C59-612V and C59-613V coils for a 3" lift so I could retain a lot of current components at stock weight. I would have to test the caster after the new coil install. I read some reviews on the Icon 3in springs which would give me the desired height and ride. The reviews are great, until you start to add weight. But I still have a 30mm spacer from one of my Sequoia enhancements laying around for any future needs... (Uses the same spacer as the 80 series for the rear coils). Thankfully I'll be doing all my own labor.
Anyways, my current plan is 2.5-3in lift with current aftermarket wheels with 35" Toyo Open Country R/T Pros. That "should" drop me around 3-4in from current state and allow me to not fall out anymore haha.
Sounds like a lot of work ahead. Good luck with the project.
Great suggestion from alia176 to connect with other owners in the area. You could possibly test drive someone else's with a suspension set up in the way you imagine would be better to see if it really is.
All I can tell you is that my stock suspension lx 450 with 265/75/16 tires has a very nice ride, so I'm leaving it as is!
FZJ80 wheels also look great and fit perfectly. They're usually a bit easier to find than the less common LX wheels.
Your GRRRRR sound on deceleration is directly related to the rear drive shaft u-joint unhappiness due to the rear differential pinion angle. I doubt it's inside the transfer case, but you are feeling it under your seat which is pretty common.
Lucky me that I enjoy wrenching!
That's interesting. I've read that as well to check the rear drive shaft. When inspecting the vehicle in purchase, the previous owner said that they put new u-joints in the rear axle. I'm going to assume not OEM and I'll check it again soon.
The grrrr sound causes a lot of noise from the Tcase shifter area. I can feel the vibrations if I hold it during deceleration. That's what has me curious to where it could be coming from exactly. I'm going to grease and check the oil(s) tomorrow. Maybe do a shake or two. Thanks again Ali!
Mine did the same thing when I got it with OME 850/861s. Lowering it made that noise disappear. As it's been said here and many other places, it's not the t-case; it's the u-joint angle.
IMO, if you drive 98% on street, you should go as low as your tire size will allow. Here's my turd. Keep in mind, I'm running 255's, so I have about an inch more clearance on either side of the shoulder of the tire than the guys with 315's and that's where most of the rubbing happens. It's easy to get into, body roll is minimal even without sway bars, ride is nice and plush, has a ton of down travel, and still will stuff that tire up to the factory bump without rubbing. Stock springs, 1.5" Metaltech front spacers, 30mm Man-A-Fre rear spacers, Gabriel Ultra Truck shocks, 1" body lift, no sway bars, no caster correction needed, and cost a few hundred bucks and a full day of work to get done.
If you want a couple shots of it flexed, LMK. There's a place I call Poser Rock a few minutes from home that I can zip down to.
It looks to me like everything that is currently installed could be retained. If it was my truck I'd start here:
  1. Select the springs you want based on your target ride height.
  2. Select the wheels and tires you want.
  3. Purchase and mount the wheels and tires you want.
  4. Install the springs.
  5. Adjust the panhard bars (track bars) to center the axles at the new ride height.
  6. Adjust the drag link to center the steering wheel at the new ride height.
  7. Test drive.
  8. Measure new castor angle at the new ride height. If your castor correction radius arm drop brackets are 2" drop then they are not enough castor correction for your 5" lift, but they are perfect for a 2-3" lift. You may find that the truck works great and has perfect castor after you lower it.
  9. Edit to add: loosen and re-torque suspension radius arm frame side bushing bolts and rear control arm bolts at the new ride height, rubber bushings twist and torque throughout the suspension travel and should be "zeroed" at ride height by torquing the bolts are ride height.
Most of the mods don't need to be undone, the last suspension installer didn't really go far enough with the corrections for how tall they lifted it.
  7. Test drive.
This is fantastic information! I ended up with the 3” Dobinson Flexi Coil (C59-612V and 613V).
For the panhards, is there a proper way to measure? From the looks of it, it looks to be correct after the drop.
Couple things that are good notes are the drag links and radius arms. I’ll take a look at those this weekend.
Cheers!
For panhard adjustment, measure from the wheel or tire to a reference on the body or frame on both left and right sides and center the axle under the truck. It’s not critical that they’re perfect. Measure at ride height after the coils settle in (after a test drive).
