- Joined
- Apr 14, 2004
- Threads
- 1,472
- Messages
- 36,766
- Location
- 818-953-9230
- Website
- www.marksoffroad.net
4x4Poet said:Let me ask about the Orion fix here, as well. Did the AA "fix" Poser delineated in post # 97 above solve all the "pop out of gear" problems with the Orion (assuming all the new shift parts are also utilized)?
Walt, I haven't had an opportunity to trail test mine yet, but I honestly believe that popping will no longer be an issue.................if I can ever get mine IN to gear!
The detents are SO STRONG and SO POSITIVE that they have overwhelmed my dash mounted transfer case's controls ability to move the hi lo shift lever. The face of my dashboard is physically buckling under the strain without result. I ended up having to build a reinforcement for the dash in order to move the lever, and am still not happy with that.
I will be removing the unit shortly to lower the tension on the fork, as I believe, as I have all along, that the stepped thrust washers, along with the inboarded detents on the shift rail, are sufficient to cure ALL problems that anyone might have had in the past.
