OME Time / Limiting Lift
Hi Guys,
So I finally got the $ to upgrade my POS-stock-LX suspension to OME. I've read up on the OME options quite a bit on here in the past, did a search, etc. and I still have some questions:
Unlike many of you, my 80 is my only vehicle, so it is very important that I keep the overall height of the vehicle such that it can still fit in parking garages, which I must park in every day (no, this is not a poser rig- I do wheel it). Right now I have 285s along with the stock LX suspension, and I will be adding an ARB non-winch bar along with the lift. I'd like to keep the overall vehicle height within an inch or so of what it is now, and I want an even front/rear stance so I will use trim-packers, if required.
1. Here's my idea: I'm thinking maybe if I removed the factory roof rack, then went with the medium load (851/860) OME 2.5" lift and ARB non-winch bar, I would end up very close to the overall height I am at now. Is this feasible? Anyone done measurements like this (various suspension combos with / without factory roofrack)?
2. I know the actual amount of lift you get from the OMEs depends on what else you have on your vehicle. How much of a height increase can I expect with my setup (ARB non-winch in front, otherwise stock) and these spring combos:
- 861/862 (1" stock height replacement)
- 851/860 (medium load)
- 850/863 (heavy load)
I ask because jlc's rig:
https://forum.ih8mud.com/showthread.php?t=77925
with the OME 861/862 stock-height replacement seems to have quite a bit more than 1" of lift.
Hi Guys,
