what spring model did you use? it this gas or diesel?
how many inch lift did the rear get? i thought 720 are supposed to give -25mm? seems taller after the ome spring. how is the ride?
Different country has different stock height of the LC200. We just dont know where the Old Man Emu got the basis of the measurment in term of height. These confused buyer like me. An example would be the OME720 this is -0.75 spring but i you install it in the middle east spec cruiser it would lift as what happend with Desert nomad cruiser. As with my cruiser here in Philippines i got stock spring but higher at least 1.5" from GXR and US ver cruiser and if i install the OME721 is it going to be the same as my original spring lift? Does anybody know where did OME got their measurment???
Finally! After long research what spring and shocks will be install. I decided to go with:
Spring
OME 700 front
OME 721 rear
nitrocharger shocks only.
Some of my friends said that using the SPORTS shocks will give a firm ride as the non sport has soft valving.
I will feel and see the height and ride.
I measured the stock height and here are the result
Front Left 28.25" Right 28.75"
Rear Left 31.5" Right 31.75"
all the measurement are from bottom of the original 17" wheel to the lip of the fender.
Dersert Nomad, Please post the picture after you install the 721 and please measure it as well. TIA!
Front measure up to 30.5"
Rear come up to 31.5"
Desert Nomad, Thank you for the post. What spring did you use? OME721 for the 31.5"? and since you installed the fender flares is it the same level as the original fender?
Yes, I changed the rear springs to the OME721, and the fender flares come out very slightly not more than 5mm.
I finally got the unit with the spring and shocks installed and re aligned the wheel. everything is just perfect as what i wish to happen.
now was
front 30.5" 28.5"
rear 32" 31.5"
measured from bottom of the 17" wheel up to the fender.![]()
