I have a lot of experience with these springs. I've run several variations of them front and rear. The shackle angle is not good in the rear, even with the light springs in a 4runner with a heavy 37" spare and tools in the back. I took the leaf pack apart and used the lower two springs (non overloads) with the upper 3 springs from the 89+ OME pickup pack. They are a couple inches longer. I moved the rear hanger back a couple inches and put a 5" shackle on it. Also using only the shortest of the overloads with it flipped upside down. Flipping them upside down is what I have found works best, as they are utilized far too quickly right side up when articulating the rear leaves and limit travel big time. This is a decent setup, but it's not perfect. The arch of the 4runner/3rd gen pickup springs is slightly different. I will likely be having a shop match the arch of the two leaf packs, but for now it is good enough. I also threw the original top two rear springs from the 4runner pack up front for a RUF setup. The lower leafs are from the OME front pack. The setup is stiff (especially with the fox shocks I'm running), but it works for me since this is a DD without any sway bars.
I also have the full OME shackle setup for sale, front and back. Used for a month. I went to longer shackles. Let me know if anyone wants them. High quality stuff but they are stock length.
