ome castor kit or slee bushings
I would go with the Slee's. I used to run that spring combo with the OME bushings and I always felt it could use more castor.
Go with Slee! I made that mistake already, ended up wasting hundreds of dollars. I am under 2 degrees of caster with the OME, I am going to go Slee 3's before summertime wheeling comes along.
Get a castor sweep first and then get the right bushings along with Landtanks template.
Best idea like said is to get your caster numbers after the lift is installed and then make your caster correction choice....
although with that said Slee's will probably work out for you just fine.
