ARCHIVE OIL Pressure Sender JIS Splitter Tee / Y FJ60 Engine EFI 3FE 2FE LS HOLLEY SNIPER CHOKE INDICATOR LAMP LIGHT CHECK ENGINE Update CNC Carbonate LENS (5 Viewers)
  • Thread starter Thread starter ToyotaMatt
  • Start date Start date
I’ll definitely need a few of these for LS and other OBD2 swaps :)
@Ned one of these would nicely finish off your 3FE conversion
What did you have no idea about? That the 3F with a carb and a automatic is a complete turd?
i had no idea the SNIPER difference made in total HP gain ...........
simply stated here , if that makes sense ?.
is this the correct OEM Toyota and or HOLLEY SNIPER Factory terminology application Nolen ?
HP / Horse Power Gain
i am not afraid to ask these basic questions , because i simply am not familiar with the HOLLEY Sniper in any level like you are ?
but , lately it has intrigued me enough to think out some stuff to help the sniper community , and maybe well ........... one day try the " M.F, " out for myself on one of
my own rigs ?
not there yet
but its occurring Teq mentally anyway ....:D
The Dakota dashes can trigger a warning light.
BTW; Barrett Jackson doesn’t equal quality. Have heard from multiple people their Land Cruisers they bought from BJ needed serious help.
Point taken on the “ barret Jackson “
I was not aware ?
Ok
Now , and should have been : My SEMA- SPEC line up of :
simply stated be me here , if that makes sence ?
is this the correct OEM Toyota and or HOLY SNIPER Factory terminology application Nolen ?
i am not afraid to ask these basic questions , because i simply am not familiar with the HOLY Sniper in any level like you are ?
bu' t , lately it has intrigued me enough to think out some stuff to help the sniper community , and maybe well ........... one day try the " M.F, " out for myself on one of my own rigs ?
not there yet
The majority of my the HP gain from a Sniper will come from replacing old worn out, poorly functional carburetors with extra drag from vacuum leaks etc.
If I had an identical 2F and did a Sniper then dropped a perfectly built JimC desmog carb on it, I would think the HP would be the same.
Same air in, same power.
I've built a 2FE for my FJ60 and I used the choke light for the check engine light. Will this be able to be refit into the stock choke light?
Yes it will and does .........:)
@ToyotaMatt
Are Female and Male ends of this adapter ALL 1/8 BSP thread ?
