ARCHIVE OIL Pressure Sender JIS Splitter Tee / Y FJ60 Engine EFI 3FE 2FE LS HOLLEY SNIPER CHOKE INDICATOR LAMP LIGHT CHECK ENGINE Update CNC Carbonate LENS
  • Thread starter Thread starter ToyotaMatt
  • Start date Start date
So what’s going on here.
you can run your Holley Sniper OIL sender and a stand alone other manual Gauge if you like , or you simply have a manual service port for a manual SHOP type Gauge
or
stand alone engine bay Gauges under the hood old skool add-on style
Will this fit a 2H block?
i am ONLY aware of one OIL Pressure Sending Unit Sender Sensor FEMALE Threads ever used by TOYOTA Globally ......
if a 2H has the same FEMALE OIL GALLEY Block Threads as a F , 2F , 3F , 3FE , 1HZ , 1HD-T ?
................then yes ..
