Riley: my floor jack is an older Allied 3 1/2ton, it came with two saddles which are interchangable; the standard 5 inch low pancake saddle and an "SUV Adaptor" saddle, which is only 3 inches in diameter but 4 inches taller than the flat saddle. Purpose is to help get a taller rig higher in the air. That is the object stuck in the pan.
The jack was part of the reason it slipped; it lets down quickly if you are not careful with the release, then having a smaller saddle under the flat axle housing. I think I tightened the release handle when I saw rig start to drop; the sudden stop may have been what caused the saddle to slip. Or another way to look at it, the rig coming down in an arc caused the jack to shoot out towards the rear of the rig.
Clutchee: If you look closely at the photo you copied, to the left of the one pan bolt you can see the cracks in the aluminum lip of the main pan that the lower pan bolts to. Some of the force was transmitted up the lower pan to the main pan. Easier to see and feel when underneath the truck.
I talked to one mechanic this morning, he says that he can weld aluminum if I have the piece.
Anyone out there know about welding aluminum?
Yeah, I was going to suggest that. They weld aluminum all the time when encountering corrosion on cylinder heads.
You can probably get that pan welded for under $50, welded from the back side so the "pan-to-pan" surface isn't really affected. If you run a welding bead along that surface, then you've got to smooth that side down. I guess that's not the end of the world, but I'd talk with my welder about just doing it from the back side if possible. FIPG will fill in any gaps.
Or if he can machine it smooth for you, go for it on the front side as well.
Gotta be WAY cheaper than a new one, and it will be as good as new.
Find a good welder in the area and have it looked at.
Then you can locate a good used pan and pickup tube, you'll be out of there for under $200 I think, plus your labor.
Seriously, get another jack, or get yours rebuilt, it's a major hazard the way it is.
I had to do an emergency pan removal in the backroads of Alaska years ago. We had only the bumper jack. (put a hole in it driving over a rock)
Ended up cutting down a small tree, using about a 2-foot long section of trunk placed on the front of the engine (on the crank pulley), took the bolts off the engine mounts, then lowered the car a bit. It pushed the engine up (relative to the frame) and I was able to clear the crossmember and remove the pan.
You could do something similar using a good high-quality jack stand (one of the tall ones) if no other choice. A better alternative would be to use an engine hoist to lift the engine.
If you don't mind laying on your back to do this, it can all be done under the truck. If you've got access to the lift, obviously go that way.
good luck.
