Im having trouble reaching hose number 1. Hose number 2 is right at the front and short there is no problem getting that done.View attachment 3591754
This is a good chance to do some relatively inexpensive preventative maintenance.
1. Purchase Hose #1 (15777-50030).
2. Purchase Hose #2 (16282-50040).
3. Purchase 4 new clamps (90467-20011).
4. Purchase new or reuse coolant.
5. If you can wait to do an oil change at the same time then purchase the gasket 15710B (90301-67004) super cheap.
Remove the shield from underneath and then drain your radiator.
If you can wait to do an oil change at the same time then drain the oil, remove the filter, use an appropriate socket to remove 15690 this has a torque spec. (If you want it I will reply when I get home.) Like I said, If you can wait this may save you from having to purchase the #2 hose.
Look at removing the #2 (16282-50040) hose to drain more since it is to the front of the engine. The hose I have labeled #2 is really short so it could be difficult to remove if it is old and stiff. I would have a new one on hand its pretty cheap.
Then with some patience, crawl under the Cruiser with a variety of needle nose, picks, and any long reach pliers and work that upper clamp off. Once you have the clamp turned around and slid down then you can either use some hose pliers to loosen or carefully use a razor blade to score the hose and remove it. Be prepared for "the rest" of the coolant to come out. (It can be done!)
Install new hoses with the 4 new clamps. Going on is way easier than coming off.
I am sure some of the smarter people will point out something as well. Good luck!
Do you remove hose number 1 from the bottom or top on the engine side?
I ordered all the parts from your list thank you.
