Oil Cooler Leak Repair guide for 2UZFE 100 series (LC or LX)
This is a good chance to do some relatively inexpensive preventative maintenance.
1. Purchase Hose #1 (15777-50030).
2. Purchase Hose #2 (16282-50040).
3. Purchase 4 new clamps (90467-20011).
4. Purchase new or reuse coolant.
5. If you can wait to do an oil change at the same time then purchase the gasket 15710B (90301-67004) super cheap.
Remove the shield from underneath and then drain your radiator.
If you can wait to do an oil change at the same time then drain the oil, remove the filter, use an appropriate socket to remove 15690 this has a torque spec. (If you want it I will reply when I get home.) Like I said, If you can wait this may save you from having to purchase the #2 hose.
Look at removing the #2 (16282-50040) hose to drain more since it is to the front of the engine. The hose I have labeled #2 is really short so it could be difficult to remove if it is old and stiff. I would have a new one on hand its pretty cheap.
Then with some patience, crawl under the Cruiser with a variety of needle nose, picks, and any long reach pliers and work that upper clamp off. Once you have the clamp turned around and slid down then you can either use some hose pliers to loosen or carefully use a razor blade to score the hose and remove it. Be prepared for "the rest" of the coolant to come out. (It can be done!)
Install new hoses with the 4 new clamps. Going on is way easier than coming off.
I am sure some of the smarter people will point out something as well. Good luck!
Im having trouble reaching hose number 1. Hose number 2 is right at the front and short there is no problem getting that done.
Do you remove hose number 1 from the bottom or top on the engine side?
I ordered all the parts from your list thank you.
I reached it from underneath. Behind the front tire. Jack up the vehicle to give your arms a chance to reach around or up and over. You can get to it. Trust me.
Nice point about coming at from the rear of the front tire, when I tried to replace mine I was still tied up in a pretzel from the figure 8 oil gasket that should be changed at the same time, the front opening I had seemed like the easy way to go if I could just sneak my hands up there. Also if that figure 8 gasket has been leaking for a time which is highly likely, that area is a mess of oil and grease. Could not agree more about this being an important item to check and complete when you start accumalating miles on the engine. Add a degreaser and some disposeable towels/rags to make your life easier. This is not a difficult job but will go onto the list of things you do not want to do again for another 150k.
Torque settings for the filter bracket assembly bolts & nut:
Torque settings for oil cooler washer and union bolt:
Not mine but an example of an oil cooler seal leak, heavy deposit of engine oil on the steering rack gear area:
Engine block oil pan is covered with oil coming from the figure-8 seal leak failure:
I also have this oil leak. I will try and tackle this on my next oil change. It seems there is a little discrepancy on the size of the socket that fits the big bolt in the housing. I'm just trying to have everything ready, so please chime in if you know which sized socket you used. Thanks
Finally got around to completing this yesterday...
Not to scare anyone off - but I can honestly say this was my least favorite project I have tackled on the 100 series. The space you have to work with is painfully cramped, to the point where multiple times it felt like an impossible task. I did this with an oil change and it took me 7.5 hours from start to finish. Glad to have this one done!
I agree. I did it wished I had not. The clearance you have to work sucks.
As mentioned previously in this thread, I will attempting this because my oil cooler housing is leaking. If the only leak is the oring of the oil cooler housing, is ok to just replace that one? The figure 8 has seen alot of time and heat/cool cycles, maybe it is best to do both?
I would do both while you are in there… It’s a place you never want to have to access twice!
i have this leak as well. the cooler itself is a contained unit and generally the seals leak (after 330k) - is that a safe 'assumption'??
the cooler isnt a part i want to replace just because, even if its off the truck.
The oil cooler is a reusable component (unless physically damaged), it’s just the seals that needs servicing/replacing. From experience with 2UZs, it’s usually at the 200k miles mark that it shows signs of leak. At 330k miles, yours definitely outlasted the average lifespan of the seals that’s a win.
thank you
Anyone replace the gasket/washer that goes to the Oil Cooler Union Bolt? It looks like you have to buy the bolt if you want to replace it.
I watched a youtube video where he replaced it on a GX. The part number is 90210-22001. I'm not sure if it will fit our vehicles though.
I did not. If I recall its just a metal washer.
I remember buying 15690 thinking I would need it and regretting that I did. Didn't need it. It is just a thin steel robust washer. If the threads are messed up on 15690 then that is when I would replace it. You should replace 15710B and the figure 8 o ring on the other drawing.
