Official ONSC member buying/selling thread (22 Viewers)
I've got a couple things from Harbor Freight that I don't need. Bought them when I was fixing my air compressor but they were not what I needed and I forgot I had them. Both are new and unopened. Free to anybody who wants them. Pick up in Charlotte or at Logan's Run.
Item # 68222 Inline air flow adjustment with gauge. 1/4" NPT(M) - 1/4" NPT(F)
http://www.harborfreight.com/160-psi-hvlp-air-regulator-68222.html
Item # 68231 3/8" Air regulator
http://www.harborfreight.com/125-psi-air-flow-regulator-with-gauge-68231.html
SOLD. Will deliver to Kenny.
Two DeWalt Drill NiCD Chargers. Both are black. Free. Pick up in Charlotte or at Logan's Run.
1. #DW9118 7.2v-14.4v
2. #DW9104 not sure what the rating is, but I think it came with an old 9.6v drill I had. Might go up to 14.4v.
I can take some more pictures. I had asked for it to be mounted to the gutters, but the fabricator felt that mounting it to the stock rack locations would be stronger. I wasn't sure about this setup because I didn't know if the roof was designed to hold heavy loads - but in discussing with LexTech and other mudders, this seemed to be better than mounting to the rain gutters (rain gutters were meant to route water). Here's the catch: You have to use larger nutserts, the stock nutserts are just too small. I would also suggest welding a couple more gutter mounts for stability.
hmmmm ok i covered mine up when panted. How tall is it? and lets do see the front!
John, I could use those please.
Wanted: black plastic cover (top and bottom half) for steering column
Vehicle ... My 94 80. No idea if there was a change for the later model.
(Oh, and a 1FZ-FE engine if you have that too)
FJ60 axles for sale - can deliver to logan's run
stock except missing lockout hubs - $300
For Sale WARN 8274 Winch $1000 plus the ride if you aren't near Raleigh
The winch was supposedly rebuilt by PO a few years ago....looking for the pics on that to confirm. The cable is new I believe as well. Great condition except a little bit of peeling paint that is easily fixable. Works great although I have never actually used it as a winch besides rolling the cable in and out. It is wired to run cable to the truck and it is actually set up to work off the dash button in the 40. I'd also be willing to sell the front bumper.
View attachment 931710 View attachment 931711 View attachment 931712 View attachment 931713 View attachment 931714
Price drop...$1000 OBO
Well built FJ40 axles for sale - listing for a friend.
Front axle has 30 spline Longfield (not Trail-Gear) chromo birfs and shafts, Longfield chromo hub gears in Aisin hubs, ARP knuckle and hub studs, LockRight locker, 4.10 gearing, disc brakes, armored diff cover, etc. The knuckles have been cut and turned.
Rear axle is a centered diff FJ40 housing with mini truck axle shafts, 4.10 gearing, spool, disc brakes, armored diff cover.
He is asking $1200 obo for the pair of axles. He also has the high steer set-up he'll take $200 for. I'll get pics soon.
Rear set up for SOA also, I assume? Track bar connections?
Yes, both axles are set up for SOA. I'm pretty sure there is a track bar mount on the rear axle. I'll double check though.
My blower motor is all messed up and i think i have it narrowed down to this:
If anyone has or knows where to find a climate control head unit for an LX, or if one from a toyota will work, let me know. The cheapest i can find one is $200. If i was working at the moment i would buy it, but with this whole leg injury happening, im ot getting paid 100%.
Thanks!
What is that pic of ?
You need the whole unit or some module plugged Into the back. I might have one but I'm afraid I might have tossed it recently. Will dig a bit but will be from a 95 LC
My blower motor is all messed up and i think i have it narrowed down to this:View attachment 938225
Thanks!
Does it not blow or just blows one speed? Just replaced a resistor in my Chevy van when the four speeds became only one. Not sure if the 80/LX method is the same.
if it just blows on high, then its the resistor. Anything other than that and its a different problem.
FS: 5 BFG Tires.
305/70 - 16. I pulled these when I went to 315's
Sorry only one pic right now. More upon request.
I'm going off an old memory but I recall 2 of them are KM2 and the others are KM.
Treads are 40% +/-
One of the tires has a sidewall cut that I didn't like even though I was still riding on it.
If one of the greensboro guys doesn't mind lending me some roof rack space they can make it Logan's Run
How about $40 each for the first 4 tires and the 5th one comes free.
How bout one of the gboro guys just buying them. I'll take em!
WTB: Part for my FJ40 Aisan Carb (connector rod for accelerator pump)
I've posted this in the classifieds also, but was hoping to source it locally so I can get my truck running.
Looking to buy a "connector rod, spring, washers/clip and lever arm for the accelerator pump" for my Aisan Carb on my 78 FJ40, FJ40Jim(Jim C) tells me that I can use parts form a 1975-80.
Looking to buy the connector rod + spring + washers (3?) + clip at a minimum, it might be easier to just keep it assembled and connected to the lever/arm so I can buy that also even though I don't need that part..
In pic, the parts in red are what i truly need, in blue pictures parts that are connected that might make it easy to disassemble and sell as a unit.
I live in Charlotte NC(zip = 28226).
Whoever sells me this will be my hero, I bought a gambler fj40 last week (non-running rig), and I think this part will get her to purr!
Pls PM me if you (or anyone you know) has an old Aisan Carb for a Fj40 from yrs 1975-1980 that they might part out or sell as a broken unit.
Thanks for your help
I believe I have sourced this part successfully via @Delancy 's box o'carb parts!
I'll know for sure in a week or so, but for now lets consider this WTB ad closed.
Thanks @Phares for offer but ended up buying a box of goodies that will likely come in handy in the future.
I'll open back up this ad/request if the linkage comes and doesn't fit, for now lets consider this mystery solved.
...via IH8MUD app
