Official ONSC member buying/selling thread (14 Viewers)
Still in search of a driver side mirror for my 97 lx450. Mine broke and when I jbwelded it some of it dropped and now it won’t adjust. Any color will work since I plan to paint the truck in the near future.
I’m pretty sure I have the housing part, just not the glass, I’ll check later.
Dell, I have a white complete mirror assy, however, the pot metal pins attaching the glass to the housing are broken; they were zip tied in , until I replaced the whole thing. If you don't mind the zip ties, it'll work. Otherwise it's available for parts.
White 2000 LX470, tan interior (Nov 1999 VIN) at Pull-a-part in Charlotte, since 09OCT2020. Absolutely no rust that I could see; appears to have been in Charlotte since at least '12 (based on the USNWC sticker on the windshield, which is cracked - the glass not the sticker).
Typical junkyard fools canabalized it, so some of the parts remaining are sketchy: case in point, the engine looks good, however everything from the fender to the intake is gone, as well as the #2 & #4 COPs, so those cylinders are full of water (no hood either). The xmsn is there, less the lower pan.
I have the sunroof. Headliner is in mostly good shape, at least until it rains again.
Fred - I'd like to claim this if @SFROMAN doesn't take it.
Anyone available for a mudship from Wilmington to Charlotte between now and Thanksgiving?
i will take it. More likely better than my current one.
Anyone interested in my old storage system? I have no use for it anymore. It's the version with the slide out camp kitchen that has its own legs.
It's a little dirty, but otherwise in good condition. I think I used the old top for something, which means it needs a new one.
No clue what to charge. Doesn't come with anything in it. Selling because I made a new/different version. You can see in the pics here, left side is for the fridge, right side has two drawers of unequal length, one of which is the camp kitchen.
Selling my dual battery setup. I’d like to sell this as a lot, so I’m not gonna sell of pieces yet
Witts End Quarter panel mount. Several things have been mounted to this and some of the screws that attach the wood to the metal worked themselves out
Orangeboxx molle panel for an 80 passenger side. I have leds mounted and wired to it
wired wagon fused relay box
battery tray, j hooks, and clamps from a 91-92
blue sea si-acr. I drilled out three of the mounting holes for a larger bolt
Various other pieces: two large bus bars, one small bus bar, military battery terminal, two mrbf fuse holders and fueses a 30 and a 100. 4 2’ sections of 0 gauge wire, a 15 foot section of 0 gauge
$300 for all this s***
WANTED-please PM if you have or know of something
I am looking for an 80 series roller. Prefer FF rear axle but not a deal breaker.
Frame
axles, complete
upper and lower control arms
radius arms
Rear upper shock mounts
Steering box
relay rod
tie rod
are you still looking for this
I have what your looking for in gastonia NC
I am indeed.
$200
Bidding war.....? Eric, let me know when the Charlotte meet is and I’ll bring all this stuff
I know there doesn't seem to be as many FJ60s around here as other areas, however, I wanted to get this out for club members first....at fire sale-esque prices.
I just picked up a 3rd FJ60. #2 was a parts truck that served it's initial purpose yet looked good enough to save and do a SBC swap. After digging deeper, the amount of body work required has grown while my available time has shrunk. I need it out of the way, so I'm parting it out. If you or somebody you know needs something (other than under the hood parts) for a 60, there's a decent chance I have it. I'll probably start cutting the body this weekend. Off the top of my head, Ive got....(reserved) denotes parts a member is currently asking for.
- Windshield
- all door glass
- cargo window glass
- multiple doors (DS front is trash)
- pedals
- steering shaft and associated parts
- steering wheel (blue-grey)
- all the climate control related stuff under the dash
- CMC and slave cylinder
- 4-speed trans (reserved) and x-fer case (reserved)
- f & r axles
- grill
- A/C components
- lower valance
- front fenders (PS needs a little work around the headlight opening...I may do it for the practice) (reserved)
- DS front inner wheel well
- Hood
- Steering box w/pitman arm
From the body core
- Roof
- All pillars
- Most floor pan sections
- Possibly lower rocker sections (I think there's some Bondo....need to double check how much/why)
