Official ONSC member buying/selling thread
Anyone interested in my old storage system? I have no use for it anymore. It's the version with the slide out camp kitchen that has its own legs.
It's a little dirty, but otherwise in good condition. I think I used the old top for something, which means it needs a new one.
No clue what to charge. Doesn't come with anything in it. Selling because I made a new/different version. You can see in the pics here, left side is for the fridge, right side has two drawers of unequal length, one of which is the camp kitchen.
Ok, so how about a 12 pack of beer?
Free to good home: trailer light kit with harness, side marker lights taillights, and license plate frame/light.
Granite counter top and T-square not included.
WTB
ONE BF Goodrich T/A KO or KO2 to have as a spare.
33x10.50x15LT
Thanks,
Rice
@onemanarmy how’s this...
Are you going to be at the meetup on Wednesday? I’m bringing some other parts for another member as well.
That looks mighty fine....I'll take it off your hands. I won't be able to make the meetup, but you can mail it, or meet some other time.
Let me know time and $.
Thanks!
Feelers / advice post ahead, beware.
Seriously considering pulling my 2FE / H55F combo and putting it up for sale. I have the itch for a hotrod, but can't have yet another project car. So I'm considering dropping a LS into Dozer to get a bit of rumble and still keep my LC habit satisfied.
The motor was fully rebuilt a few years ago and has a couple thousand miles on it (I'll update this with actual mileage).
Block was bored and head shaved, so it's pretty high compression and requires premium fuel. Can be detuned for regular, but takes the power down considerably.
Rotating assembly was fully balanced at the machine shop. New pistons, rings, bearings. Fuel injectors were sent for service.
Delta 250s cam. New lifters.
Running aftermarket ECU I built and tuned from scratch. Megasquirt MS2. All wiring, including MSD ignition, fuel pump, sensors etc would be included. This ECU is capable of boost control and multiple spark tables (was going to be my long term plan).
I have the tune about 95% dialed in. Takes more spins to crank than I like, which I'm working through as colder weather is coming. Also has hesitation on throttle up without load (not when actually accelerating, just when sitting still at idle and blip the throttle). That can be tuned out as well, but I've not spent enough time trying yet.
I can tell you she will spin up to 5K with ease, and runs a lot stronger than your typical 2F or 3FE. Dyno'd at 145RWHP and over 200ft/lbs from 1500 through the RPM range in 3rd gear (dyno guy didn't trust my tires at top speed, so wouldn't dyno it in 4th). I'm guessing it's north of 175BHP.
2 oil leaks need to be addressed. One is the rear main I'm pretty sure, and the other is the crank pulley. Pulley needs a speedi-sleeve for sure, since I tore it all down and very carefully installed a new OEM main pulley seal and it still leaks a tad. Only a few drops after sitting and not enough to need oil fills. New owner could easily address while the engine was out.
H55F has a little glitch going into second until warmed up, then smooth. No other issues with the motor / tranny I'm aware of.
What would you guys think would be a fair asking price? And is there anyone even remotely interested that wants to chat about it?
:beer: Ramon
@jfz80 Im on a budget build. That combo sounds amazing though @mtweller .
