For all those interested here are some pics of the pump setup as mr Yota installed it, the aftermarket "Long Ranger tank" and the standard 80 series sub tank (to compare to the 100/105 tank)
When I installed mine, I just disassembled the two parts like you have and was able to very easily get them into the truck. I cannot recall if I went from the front or rear, but it was not a struggle to get it into place. Then bolted them back together/into the capture-nuts, drilled the additional mount holes that are not in our rigs, and it was good-to-go. The only difference I can see with yours is that you still have the rear line attached, and I did not.
Steve
Before I break out the angle grinder and cut a piece off, I wanted to see if anybody has been down this path and has a better solution.
The picture 1 shows the transfer pump and solenoid assembly as it came from AU. Transfer pump and solenoid are on a bracket, and that bracket is attached to another bracket containing plumbing. Pic 2 shows the two brackets separated, and though shot from the top, the offending tab is slightly visable in the second shot.
Many OEM sub tank installations have proceeded without the plumbing bracket piece.
It appears that the plumbing bracket serves more as a heat shield from the exhast rather than any kind of mounting bracket (plumbing can readily be routed with soft hose).
No problem mounting the Pump/Solenoid bracket to the pre threaded holes. However I have tried threading the plumbing bracket in from the rear (pic 4) between the cross member and the body. The second Pic 4 (sorry, should have been pic 5) shows the area in front of the crossmember. I have tried removing the last section of the OEM exhaust, the front strap of the main tank, and tried threading the plumbing bracket over the cross member from front to back.
I think my only option to to trim the tab off with an angle grinder. Any idea what purpose that tab serves? Anybody installed this this bracket without triming the tab, or more drastic options to get more clerence.
FWIW - I only bolted the transfer pump bracket in with the few captured nuts that were already there. I used thread lock and lock washers, so far it seeems secure and has not come loose in 1 1/2 years it has been there. I didn't bother with drilling additional holes in the floor.
and I will be watching to see if anything pops up over the weekend. Feel free to PM me if you run into any glitches.
...The threads documenting this mod, are full of schematics, color coded wiring diagrams, pages from the FSM, but nothing "speaks" to me...
I have seperated the overhead console wiring harness, so that I only have the bundle for the sub tank gauge and the altimeter. I beleive the harness and the gauge pod came from the same vehicle.
Note that there are 5 wires on one side of the plug, and 6 wires going down the A pillar
Does that look right?
I beleive the black/white wire is the ground.
Can somebody tell me what the other wires going down the A pillar are for?
If I combine the comments in post #48 and post #179, i think this is what I get for wiring in the sub tank Switch. (wire colors will vary by the model year of the donor vehicle).
Empty slots seem to correlate to photos in post # 107
Primarily interested in correctly identifying the purpose of the pin. Does this look right ?
The following is a suggestion from a previous post, on how to hook up the wires coming down the A pillar for the overhead console:
You can ground it to the vanity light/moon roof ground wire and run 4 wires down the A-pillar; 12V+ to the 10A Gauge Fuse, 12V+ to the 15A CIG fuse for back light, one to the dash rheostat switch for the dimmer function & the gauge signal wire. Routing the wire down the A-pillar is not too bad if you are patient & use a semi firm lead wire to pull the softer wires through.
Once you find the fuse box and the respective fuses, how do you attach wires?
How to get at the rheostat switch?
+tired=
