HI just finished transfering a bit more into the main and it automatically shuts off when the main tank is 75% full.
The main gauge shows a bit less than 75% when shut off occurs (see pic) and it takes several minutes for the main gauge to show 3/4 full.
and thanks for all the help.Jim, would you have the part # for the Subtank "Fuel Level Switch / Gauge Sensor"? This is the one which tells the system to shut-off when the sub is empty
Steve
Oh shoot, a 100-series tank, really?
Well that stinks, sounds like I will have trouble with the straps then.
Chris -
That tank appears to me to be the one used on the 105 (the straight axle version of the 100). I have a pix in my files labeled "105 subtank" that is identical to the pix you posted above.
Hi Ron,
Excellent idea...will pull the sensor in the next few days and give her a good cleaning and testing before ordering a new one (appx $60 from Japan). Luckily I added the OEM access panel from inside the truck so I can pull it quite quickly and easily...the tank stays in!
Steve
