OEM 100 Series Hand Throttle -- Available (4 Viewers)
Got everything today, thanks !
There is another hole in the corner just above the hole for the cable. What is it for?
Also do you or can you supply the C clip that locks the cable onto the bracket?
Shane.
Awesome. Now we are waiting on some installation results.:hillbilly:
Sorry the c-clip 90082-61004 was out of stock when i ordered the sets. Your dealer should be able to get it for under $2.
The hole above the cable hole is for regular screw which holds your bezel.
2 sets are available. Bezel is not included.
Price is $110 shipped
Yan, I am wrapping up my write-up page and will post it over the weekend or on Monday. I have installed the throttle and it works great.
I don't know if the clip has come into stock at your dealer, but I would recommend adding it to your kits if these become more popular. I had to source one from my dealer...not a big deal, but nice if it all came from you.
For others, the clip with part number 96160-00400 on this drawing:
[URL="http://i962.photobucket.com/albums/ae109/akella220/105handthrottlediagram.jpg"][URL="http://i962.photobucket.com/albums/ae109/akella220/105handthrottlediagram.jpg"][/URL][/URL]
has now changed to part number 90082-61004. If Yan is unable to get these in the kit, you can pick them up from your local dealer or Beno.
Here is what it looks like:
This keeps the the cable assembly from slipping off the arm, which is definitely useful if you don't install the manual hand throttle in the stock location.
Awesome.
I can get the clip, it just was out of stock at time of the order. So I asked you and Shane to call your local dealer for it as i didnt want to put on hold all the part just because of $1.50 clip which is available at local dealer in North America.
Next kits will be supplied with all the required parts except lower bezel until further investigation on availability and source.
:bounce::bounce2::bounce::bounce2::popcorn:
any chance you still offer these?
Seems just a bit shy in width. Everything except the trim around the ignition and righthand side of the panel seems to line up fine. No amount of fiddling or dremeling will fix it. It's too small. I had already trimmed out the leftside switch bank to fit Contour switches before I tried to fit it and couldn't return.
I WANT ONE....
Sorry guys if i missed your message. Have an issue with notifications. Please PM me
Currently have 2 kits in stock (bracket, cable, knob and nut)
@tlc81 PM sent
Are these kits still available? Id like old skool crawl mode on my truck please.
