Thank you. It would have been SO much easier to just get rid of the ribs altogether and throw in a piece of flat, it's gonna be covered by oe floor mat anyway... But I would know it was there, and that just wouldn't do. I wanted the repair to be as true to original and invisible as possible- and (usually) when I do something, I want it to at least appear that I gave a s***. This time, I feel like I accomplished that.You should be proud! Very factory looking.
Shaping and forming metal looks easy and is very far from it.
Watching ... I have a hardtop when the PO also cut off the posts. So I also need to replace them. Looking forward to seeing your solution.Did some hammer and dolly work on the hardtop pieces
I will be sure to take good pics/measurements when I reach this stage. Are yours cut flush or do you have a stub to work with?Watching ... I have a hardtop when the PO also cut off the posts. So I also need to replace them. Looking forward to seeing your solution.
Cut Flush. My first thought is to make an insert with a piece pipe and then tack weld it onto the top. I have access to a metal lathe.I will be sure to take good pics/measurements when I reach this stage. Are yours cut flush or do you have a stub to work with?
I think the insert sleeve is a solid plan, you could machine a snug fit and drive it inside the stub in the top a few inches and stick out the bottom a few inches to stabilize/hold straight the new spliced on pipe section. The new pipe section could be plug welded to the insert. Do you have any rust in that area to contend with like mine does or is the missing pipe the only damage?Cut Flush. My first thought is to make an insert with a piece pipe and then tack weld it onto the top. I have access to a metal lathe.
