I had an idea and ran with it. Its been doing good so far probably 6 or 7 trips and 3000 km or so since I did this. I originally posted on a fb group but now I have had it longer and a few other guys have tried it with success.
From day one I always felt the 80 had a dead spot in the steering. You really noticed it when there were grooves in the road. You would chase the steering back and forth trying to keep it straight. I started to look at what the hell was going on. First I checked all my bushings and tie rods. Replaced tie rods and track bar bushings because they looked to be original. Issue persisted. I noticed when tires were on the ground and you dry steer the steering shaft coming through the firewall moved up and down like it was bent. Upon further investigation I noticed u joint to rag joint to another u joint right before the steering shaft goes through the firewall on the inside. When you try to steer that rag joint would torque up or down and you could feel the play before the wheel started to move. So I went down the mud rabbit hole and found a couple things.
1-find your feet get hot or it stinks in the cab of hot motor? The rubber seal that rides the steering shaft is probably gone leaving a hole right at your feet.
2-there is an adjustment nut on the steering box to take up slack.
3-there is an adjustment at the tilt steering mechanism that allows you to remove up and down play of your steering wheel.
4- the only way to stop that rag joint from moving around was to add a bearing. This also greatly increases the life span of the bushing.
Now lots of people had tried the bearing technique and complained about it squeaking and it drove them nuts. So I thought about it and came up with a system that so far has worked flawless. After going through these 4 items I have no dead spot and it's nice and responsive without a squeak.
1- get a new rubber seal from Toyota along with the rag joint. I got my rag joint off rock auto because I'm a cheap.
2-order a steering shaft support bearing off ebay 20mm or 3/4"
3-get a pack of these springs, 2 m6x60 bolts, 4 m6 nuts, 6 m6 washers, 6 m8 washers, a peice of thick shink tube that fits over the bolt.
4- lay it all out on the bench
5- crack beer
6- climb under your dash abd remove the old rag joint and slide the old seal off the shaft.
7- cut two springs in half. And this part is a bit specific to your bolt. I used a 50mm bolt but I wish I had 60mm it would give more clearance to the fire wall.
8- Slide m6 washer onto each bolt.
9- Cut shrink tube to just longer than the part of the bolt without thread. Heat it up and shrink to to the bolt.
9- Slide one half of the spring on followed my a m8 washer. Do this for both bolts.
10- Now slide the bearing assembly onto the bolts then another m8 washer spring then m6 washer. Put one nut on the bolt and tighten it until it bottoms out the thread. You not have floating bearing assembly. That has the ability to move with the shaft and wont squeak.
11- Install a second nut, you may want to get a couple extra nuts and use them to take up any extra thread so nothing can come loose. Leave enough thread that there is 15mm or so past the new seal or so to be able to re bolt to the fire wall. Don't forget the washer infront of the seal!
12- Climb under the dash and slide the assembly downtown the fire wall and tighten the bolts up. Then tighten the set screws onto other shaft.
13- Have another beer, you have been doing yoga for 15 minutes under the dash you deserve it.
14- Now the hardest part I found was getting the new rag joint back in. Sliding it over the shaft is simple but getting the steering column side to line up again was hard. I ended up getting a hand and unbolted the column, pulling it back ever so slightly to get the bolts in.
14- Once installed make sure you tighten everything up! It's your steering double check!
15- Take it for a drive and feel the difference.
Mine has been this way for 3 offroad trips now and no squeaking of any sort. Steering still feels nice and tight. So I figured it was time to share.
Hope this helps some one out! See you guys on the trail!
