Lookin good! Be interested in seeing how it all behaves once you get it back on the road. Keep up the good work and quick progress!
Thanks man! Can't wait to have it backLookin good! Be interested in seeing how it all behaves once you get it back on the road. Keep up the good work and quick progress!
Right on. I'm running 200/350 which is about 16 lbs/in stiffer. It's fine but I want more preload so I think I'm going to drop down to a 250 lower as well.I got the coil overs. But went with 200/250. It's what King reccomended and @Apounder is running the same.
Wouldn't that be 100 pounds per spring stiffer? From what I can tell to read spring rates is the weight stated compresses the spring one inch. So for a 200lb spring it takes 200lbs to compress it one inch. But could be wrong?Right on. I'm running 200/350 which is about 16 lbs/in stiffer. It's fine but I want more preload so I think I'm going to drop down to a 250 lower as well.
Not at all, no.Wouldn't that be 100 pounds per spring stiffer? From what I can tell to read spring rates is the weight stated compresses the spring one inch. So for a 200lb spring it takes 200lbs to compress it one inch. But could be wrong?
That is true for single springs, when you have dual springs there is a formula to follow, but most people use a spring calculator. The short of it is you compress both springs with 100lbs not just one of them. So with 100lbs and a 200lb spring and a 300lb spring, you would compress the 200lb spring 0.5" and the 300lb spring 0.33" so a combined total of 0.83" for a spring rate of 120lbs/inch.
Ahh makes sense.Not at all, no.
This, but it's easier expressed as the formula:
Spring 1 * Spring 2
Spring 1 + Spring 2
so, in this case, 60,000/500 = 120 lbs/in.
200/350 = 127ish lb/in
200/250 = 111ish lb/in
Bear in mind that standard ome or tjm front lift coils are often in the 300lb/in range, plus the OE sway bar offering some 150lb/in of roll resistance, plus you have the giant sway bar known as the axle tube when connected with radius arms.
Going from 450lb/in + the radius arm roll resistance to a mere 111 lb/in and you're going to definitely notice the ol' swoopy mc swoopyface suspension that everyone pretends isn't there.
Itll be pretty noticable.Ahh makes sense.
Yeah I know there will be much more body roll but won't be too bad.
Oh man those bumpstops thoGetting it buttoned up! Sitting on its own weight and just little things to do now. Going to pick it up Friday assuming limit straps come in by then
View attachment 1574501 View attachment 1574502 View attachment 1574503
yupDamn, looks slick!
What did everything get painted with? I see lots of shops out west (via the internet haha) just spraybombing suspension and frame modification projects for customers. Where I live aerosol paint lasts less than a year so we have to use stuff like imron or base/clear if it needs to stay looking nice and not rust.
thats why your doing mine soonThe sheetmetal work on the fenders is terrible but do appreciate the rest of the project and the boat-like money you're dropping.
Not saying it won't be, but in my opinion it isn't bad. I've been in and driven Andrew's many times.Itll be pretty noticable.
For the spare? I'm undecidedJust found this thread...Super fast build.
What are your plans out back, are you going with inside or outside with that huge 40" tire?
