Yeah but it's not... it just makes the binding happen more readily by forcing the tie rod end into polyurethane. People try to implement crossover steering as an improvement over y/t-link geometry because it sucks.
I think you'd be better served putting them on the tie rods but they're still garbageOhh I got one of those on there.
What? No, it's to retain crossover steering... either like the factory had it, or with a traditional high-steer drag link, low-steer or high-steer tie rod, etc.Sounds like the only answer is full hydro then, or just run it like everyone else has for years.
In my opinion the Tcase gears are a huge improvement & the only chance to reduce gearing. Unlees you want to go with a 60 series manual & Tcase. On the H high end there are 10% under or over for more options on pavement.Stock wheel base is 115", at least where I looked? Internet info for ya.
Yeah debating on the gears.. I have an appointment at Torfab on the 24th to have them done but not sure a 25% reduction is worth nearly $1500.. we'll see, hopefully going to test Andrew's on the rocks this week and that'll tell me.
Hey Apounder's truck looks great!
I agree with Nukegoat's comments regarding y-link steering. I have it and it sucks. You'll learn to live with the clunking sound when you turn the wheel each time. Y-link is a compromise you make due to space and interference. What you really want it crossover steering. I'm looking at ways to make it work on mine, but it will involve notching the frame on the passenger side.
I also had RuffStuff's "The Cure"and their TREs, both of which I thought were pretty poor. That Cure spacer didn't last. In a Y-link setup that tierod NEEDS to roll by design, that's just how it works. The Cure spacer tries to limit some of that roll and dead spot but IMO it doesn't really help.
Just wheel it till it needs fixing![]()
Yeah im not worried. Andrew and many others have been wheeling it for years without issue. Im used to how it drives so don't really care to change it unless something bad happens.Hey Apounder's truck looks great!
Fly out for an event (TnS, Rubithon, etc.) I've taken a few out of towners wheeling with me in the past and a passenger is almost always welcome especially when they are bringing some quality adult refreshments.If you guys weren't a nation away, there are some dudes (including myself) here in NC who aspire to get to this level. Would looooove to see these rigs in person. Great build, keep it up and have fun taking this build in a direction not many people go! I'll be following along.
I would probably suggest part timing the t case while in there. I didnt and sort of regret itCruiser is sitting at Torfab on the lift ready for transfer case gears tomorrow. Miscommunication as my original appointment was Monday but they still got me in.
Not going to. Thought about it but like having the awd for going over the mountain passes in the winter and not having to pull over and get out to lock hubsI would probably suggest part timing the t case while in there. I didnt and sort of regret it
Its totally fine to keep awd but if you end up wanting more caster but dont want driveline vibration, etc, you need part time to do so. Just limiting overall. But yeah, i didnt either.Not going to. Thought about it but like having the awd for going over the mountain passes in the winter and not having to pull over and get out to lock hubs
They built mine with 6 degrees caster and I like where it's at, don't really see a need for much more.Its totally fine to keep awd but if you end up wanting more caster but dont want driveline vibration, etc, you need part time to do so. Just limiting overall. But yeah, i didnt either.
