hey, I have searched and didn't find an answer so here goes
I have a 78 40
I have a non usa dizzy, which is basically a E-68 vaccum advance
with a ballast resistor wired in on the + side of the coil to a switched black with yellow trace 16ga or 18ga wire
1: which coil should I use? the one listed for the 78 or the one for the 68? I would think the one for the 68, why are they different?
2: can I wire the + side of the coil directly to the "pink yazaki resistor ignition wire" I have read about from Jim C, or do I need to keep the external ballast resistor and wire it to the heavy gauge black with yellow trace switched wire?
3: all the coils are painted, how are they getting grounded? is there a good way to do an external ground?
4: is there any negative issue with heat, of mounting the coil to the side of the head?
euUrb
I have a 78 40
euUrb
