I drove my 80 home friday night...saturday morning went to start it and it didn't start. Went through some basic diagnostics...had spark - no fuel. Tore into the service manual...with only a slight glitch...I have the FSM for a 1993 and mine is a 1995...hopefully I am still on the right path.
Pulled the second row of seats and got to the fuel pump. Put 12v on it and it works. Put it back into the truck and try cranking, it cranks, but doesn't start. Start digging through the manual a little more. Checked the EFI main relay...seemed to be the problem when you look at the diagram found on page EG-296. It appears that they might have rotated the relay because the terminals on the relay are off 180 degrees as shown in the manual. If I am right, then the EFI relay is not the problem...
What does seem to be the problem is either the fuel pump relay, fuel pump switch or the circuit opening relay...
I attacked the circuit opening relay
Went through the relay inspection as outlined in the manual. (pg EG-298 for those following along in their 1993 FSM) It appeared that it was bad, so I got a new one at the dealer - PART NUMBER 90987-04002
Put it in, cranked it, no start - went back and checked the relay and it appears that it is bad as well - atleast according to the FSM. Anyone care to check one that they have? It is located at the bottom of the drivers side kick panel...not too bad to dig into.
Checking for continuity, I don't get the required continuity between STA and E1...does your relay get continuity here? I would get another from the dealer, but they won't have any till tomorrow.
I could use some guidance here...any help would be appreciated...I am not sure if I got a bad relay or if I need to keep looking for my problem and the FSM is incorrect with regards to checking the manual. If I hook 12v up to the fuel pump, the truck will start and run.
some additional information (not necessarily pertinant, but who knows) I installed the CDL switch last week. In the process, I took out the little Toyota security panel switch-siren, whatever that piece is...and didn't put it back in, I just unplugged it...I drove the truck for several days like this, so I don't think this is the problem, but who knows.
Happy Trails
brian
540.478.4747 cell
Happy Trails
brian
540.478.4747 cell
