I tried it and it tested good.
Did you do a load test? I have had a lot of batteries show full voltage with no load only to die when the key was turned.
I don’t have a way to test that. Where could I go to get that test done? Could I jump start the car and see if it starts that way? That may rule out of the battery is no good right?Did you do a load test? I have had a lot of batteries show full voltage with no load only to die when the key was turned.
Did you fix the problem?Ultimately find the culprit? I have had similar issue with no luck finding the problem. Starter and alternator have both been replaced fairly recently - not due to this. Periodically I can turn the key and dash light illuminate, but no crank. Not the immobilizer I’m thinking since the flashing red light by the radio goes off when key is inserted. On other occasions it will crank but not start. I can continue to let it crank and sometimes it will start but sluggish when it initially catches. If instead I back off the key and the turn it again it generally starts right up.
Fuel pump has also been replaced. In one sense it seemed like fuel wasn’t getting to the engine so it would fir, but I’m not certain about that. I’m also wondering if it has something to do with the ignition itself. Or, maybe some other electrical gremlin like a relay.
A crank position sensor on the fritz can also cause your issue. Any codes in Techstream?I am dealing with the same issue with same symptom. What I also noticed is the ABS relay buzzing. Starter was replace less than 10K miles ago with one from Lexus dealer. Battery is a few week old when I first experienced the problem intermittently and the old battery was tested bad. I replaced the fuse box with a new one yesterday and that's not the culprit.
forum.ih8mud.com
Assume dash security light goes off, when key in IG SW. Sound like starter. They give early warns just like you've described. May be opening and closing hood, jossels starter contact. Further clue, would be. Tapping on starter then it starts. Which chrome bar in tool it is usefully for.Hi All,
I have the issue that has been pretty well described in this thread.. ( have 2000 LC100)
I put the key in, all dash lights come on... but as soon as I crank, all electrics get cut off. engine never turns over. not even a little.
- 2 new batteries have been tried. although battery was ruled out positively before anyway.
- it take a couple of minutes for things to reset, before I can put the key again and dash lights will come on. if I immediately try again, all electric would remain dead for a min or two.
- this can happen even after driving the car for hours or hundreds of miles on a trip. I could turn it off to fill up gas, and then no start.
- has been happening for over a year. (answer below, if you wonder, how I've been managing!)
- rarely it starts again after waiting a few minutes and trying again.
- I can consistently get it to start, -- ready?! by disconnecting the battery negative and reconnecting. this works every time. and then there is normal crank. which confirms strong battery(two different batteries have been tried.) and normally functioning starter.
I think there is some electrical thing, that when the first crank attempt fails, as there is no real crank, it is capable to cut entire electrical system of the car off. and this can be easily reset by reconnecting negative terminal!
what do you guys think?
lots of people reported this problem. what is the root cause?
Thanks,
I have had starters fail on me before. and this one isn't smelling like starter. (I know they always fail in different/new ways every time.)Assume dash security light goes off, when key in IG SW. Sound like starter. They give early warns just like you've described. May be opening and closing hood, jossels starter contact. Further clue, would be. Tapping on starter then it starts. Which chrome bar in tool it is usefully for.
No but if battery drops too low, dash lights go dead. Which with bad starter does sometimes draw on battery. Make sure you test volts directly on battery post, then on clamps or further downstream. Volts should be the same all points.I have had starters fail on me before. and this one isn't smelling like starter. (I know they always fail in different/new ways every time.)
don't think it's hood opening jostles it! as I can open the hood and close it as many times, and it won't change anything until I disconnect and reconnect the negative terminal. (I suppose I could also reconnect the positive, but my natural instinct is to do it on negative.)
so, something gets reset, with battery disconnect, that makes it work perfectly after every disconnect. and it won't work until a disconnect. or sometimes I can wait a few and try again, and then wait a few and try again, and it might work eventually without disconnecting the battery, but at this time, as soon as it doesn't start, I disconnect the battery, and it works after that 100%! I have installed a quick disconnect terminal also! LOL
most puzzling part being all electrics cutting off through the car after a failed crank. if starter is bad, could it cause all electric to cut off? only after a failed crank..
This doesn't sound normal.I put the key in, all dash lights come on
Oh! I took as key and turned to on. Good catch.This doesn't sound normal.
Check fusible link and battery cable connections. Sound like problem is close to the battery.it is capable to cut entire electrical system of the car off
I am sure there is ground in the starting circuit to trigger those relays. Unfortunately I don't know the location.A ground single fault I suppose is possible. I don't actually know of a ground signal in the start circuit, but there is likely one. If so disconnecting battery, and the surge reconnect, may trip the circuit. @medtro do you know of one. Perhaps in a cowling junction box? IDK!
