It's easy to disconnect the MAF Meter from the Connector (wire-harness plug housing), if that’s what your referring to:Not sure how easy it is to disconnect the MAF.
I tried when I was cleaning the sensor, but it didn't bulge.
I am in Tapping.
Place a wide-blade screwdriver between top center of MAF Meter & Connector housing. Gently pry by twisting blade back and forth, while holding-down back of connector release clip. Once connector is disconnected remove the two screws and gently pry-up MAF Meter working around sides to removed ..... being gentle is key …. do not force and avoid edges of connector plug area.
Here just one more thing I didn't no and don’t know why?
The FSM states: under Inspect MAF Meter; (b) Inspect for operation; (7) Disconnect the negative (-) terminal cable from battery.
and I agree do all parts now. If the budget will allow; I'd have shop check compression while they're working on it, they can also scope valves & pistons tops for you.
