Yea, about like that. Kinda like a wet dog. Not from snow either...I have nothing of value to offer other than the fact that the dog in your icon is how I imagine you looking while dealing with this...
Good luck, sir!
Hi, did you get an outcome after changing fluids etc?Looking into a new issue with a new to me cruiser.
When you put the vehicle in reverse or drive there is a very slight change in our p.m., and the vehicle will not move forward or backwards. The brake is off. Same thing happens in high or low gear.
Any thoughts?
Thanks, managed to sort, basically fuse change and high low gear fiddling@AJGH It might be better if you started a new thread and described the symptoms you're 80 series is having.
On the 80 series the fuse which the brake lights are on also has the automatic transmission lock so it must be a feature to stop you driving without brake lights, fuse number 4 in the internal fusebox next to drivers sideSo a short somewhere in the transmission harness??
