Last week finished up a radiator replacement including thermostat, gasket, hoses, etc... and have now found a coolant leak that wasn't there before.
I can't tell exactly where it's coming from. It is only leaking when hot and driving. Have not been able to reproduce it sitting in the garage with wife revving the engine.
#1 looks like it is on the water pump on seam between where the heater pipe and bypass outlet connects to? Is there a gasket there?
#2 Could also be the water bypass outlet where attached to water pump? Are either of these more common, or am I just looking at replacing all the associated gaskets/o-rings?
I only replaced the thermostat and its gasket, didn't go any deeper than that into the water pump.
Thanks in advance!
Thanks in advance!
