New rough idle at start, need advice (1 Viewer)
KingAir Driver
Spokane, WA
Looking for a little advice on my new rough starting/idle issue.
Backstory: So I decided to bring the 73 home to work on it more. It had been running fine, drove it up and down the street a few times. The morning I go to grab it, has a hard time starting, barely idles, backfires out the carb, accelerator pedal has almost no affect (no revs). I goose the clutch to get it up the the trailer ramp, as soon as the front wheels hit the ramp, Everything clears up! Idles great, back to normal. Get it home, drive off, go around the block. Good!
Let it sit overnight, back to be rough, won’t stay running. The carb was rebuilt, new tank, fuel pump and dual filters. I’m perplexed if it’s carb related or dissy related? The fact that the issue resolved when I went up the trailer ramp is odd.
Any help would be appreciated.
When's the last time it's been driven for a decent amount of time?
Might be too easy but maybe you just need to take it out and really drive it. Mine will do that if it's been sitting
Yea, I’d ran it for a good 30 mins the week prior. Never had this issue on start before.
Quick, simple check is looking at the dipstick; overfull, smell like gas, etc?
does it run better with choke on or off?
Oil level is ok, no gas smell. Cold starts have normally needed full choke and then after warm up no choke is necessary.
Just checked spark and coil = good
Power valve squirts gas, but struggles to stay running.
Carb Sight glass half full
My clear fuel filter prior to the carb is fuller than I’ve seen. I’m leaning towards something is plugging the carb, no gas going from the jet’s.
Did you flush gas tank? My guess is something clogging needle valve at carb or something clogging intake at gas tank.
New gas tank, filters, and fuel pump. Going to open up the carb today and look for obstructions.
That answers the gas tank question.
Carb opened up, all ports are clear, needle valve and float operating. Blew everything out to make sure. Still doing the same thing. Struggling to stay running.
Switched to ignition side, point gap looked good at .015, rotor and distributor cap clean edges. I tried advancing the timing to 17-18, started running a little better but got smoked out of the garage. My timing light has the RPM readout, but it was very erratic going from 1000-200-600 in a 1 sec span. All the plugs show a black carbon glaze on them. Recheck of the coil next, wonder if it’s a weak spark or signal.
Hey King, have you gone through the FSM tuneup procedures to try and isolate the issue to the carb or dizzy? I would test the idle solenoid and make sure it's clicking properly and its wire is not grounding out. I have seen them ground out through the insulation if it's degraded at all. Have you checked your timing yet or looked inside the dizzy? How about vacuum leaks, have you checked for those around the manifolds? After all of the replacements that you mentioned above, is your gas tank getting proper vent or is it drawing too much vacuum? Just a few thoughts from my experiences. I'm trying to plan a trip to Spokane with my boys, so I could stop by and lend a hand (or a :beer:) Good luck!
Sorry, it sounds like you have already checked most of what I suggested. I would only suggest that 17-18* degrees seems way to advanced for idle timing. Both of my 40's run best right on the BB at 7 degrees. As long as the vacuum advancer is working correctly.
@AntFarm thanks for the offer, welcome to stop by any time. Yea, I know it’s way too advanced. The 73 has a vacuum retard dissy which is capped off. The carb was set up per the FSM and running great prior to this incident. The idle solenoid is clicking when keyed on. Manifold gasket’s are on my list. Just going to keep checking everything.
Welp got it running and drove her for about 10 mins. Here’s my course of events.
- New plugs ( spark tester was showing a weaker signal than my buddy’s 40)
- Pulled the idle solenoid to check that it bench tested good. It did.
- Shot carb cleaner through the idle circuit and then compressed air.
- Used starting fluid to get it initial running more the 5 secs.
-Saw gas coming out the center Venturi, which it shouldn’t at idle. Played with some carb screws.
- Had a buddy turning the distributor to get it to stay running, Venturi stopped giving gas.
- Adjusted the idle screw and mixture screw utilizing lean drop to get 650-700 rpm, choke all the off, 15 in vacuum.
- Tried to set timing, but the signal on the spark plug was erratic and wouldn’t give a constant strobe.
Of note, checking the gas cap, the tank was really pressurized. Left the cap off during these above events. Still smoking pretty good which I’ll attribute to valve seals for now or unburned gas due to weak ignition
Hopefully it starts again when it’s cold. I’m going to upgrade to a DUI distributor next. Also, get a vented gas cap until I can figure out the pressure.
Pretty much got same issue...40 was running great, then all of a sudden barely will stay running in idle. Low RPM + lots of fumes (rich??) Runs fine with just a little choke and with choke off at driving RPM. Background: new plugs, dizzy cap, rotor, wires have been replaced, idle solenoid wired directly to ignition...seems to work fine. Kind of leaning to obstruction in carb...put in some fuel additive which may have "knocked" something loose. Looked for vacuum leaks by spraying carb cleaner around usual places but no increases in RPM anywhere I could find. Ideas??
FWIW:
When you have to add choke to keep idle, you’re running a lean condition. The choke restricts air, essentially adding more fuel to the mix. You have to adjust your air / fuel mixture richer, or there is an obstruction in the idle circuit you need to remove. At higher RPMs, the engine is creating enough vacuum to draw fuel through the main circuit, and not through the idle circuit, which would be why you do not need choke when driving.
What's the best/easiest way to clear idle circuit blockage?...short of rebuilding carb which is out of my league. Thanks.
First thing I’d try is backing the idle mixture screw all the way out and giving the port a blast of compressed air and/or carb cleaner.
Then move on from there if that didn’t work.
BTW: A carburetor rebuild is easier than it seems. You CAN do it.
Assuming all the parts are there. I could have disassembled and re-assembled my carb for sure, but I wouldn't have realized or noticed some of the missing bits that Mark A did when he rebuilt it thanks to a previous owner that didn't know what they were doing. He was amazed when I stated that the 40 ran OK. I'm sure it will run much better now!
