New reverse lights for a GXL - A saturday afternoon project.
Australia
Hi All,
I wanted a little more light at the back of the cruiser for reversing on bush tracks at night and in the campsite when pitching the tent/loading unloading stuff etc. I was going to cut a light into the bumper however saw a GX model that had different bumper lights to my GXL. After a bit of research ended up with a Saturday afternoon and thought I would share if anybody is interested.
1. Standard GXL bumper red reflector with no globe.
2. Buy a pair of Left and right standard GX model bumper reverse lights and dont forget to get the matching
plug.
3. Next was after market 'rear lights' switch that fits into the standard Landcruiser 200 dash and I changed over the reverse lights that can with the standard pair with 11 W 12V LED (1500LM)
4. I took the bumper off for access and to put the cabling through the body (in the red circle). The other
photo is showing how the back of the standard red reflector is bolted to the inside of bumper.
5. After running new cables up to the dash and with associated relay, fuses and switch complete as quick test and bolt up the rear bumper.
I think if you had the right tools, you probably don't need to remove the bumper only if the splash panels and if you were really excited, maybe the wiring exists. I wanted total flexibility with lights that I could turn on and off from the dash with or without the engine running or in our out of reverse.
Looks good mate, can you please advise of the part numbers for the lights and where you purchased the switch. Thanks
Great mod! Did you find any pre-wiring for lights behind the original red lenses? I've seen the kits for red or white replacement light units, but wasn't sure if the LC is pre-wired for any lights in the bumper.
Hi Spudman - The only numbers on the right hand light was 60 175 R E11 5719, I will have a look in the daylight on the left light. I bought them off ebay.
The after market switch was from http://www.newpro-tech.com.au/Clights.htm.
Brussum - There was no pre wiring that I could see - certainly no cables. There were a number of connectors under the bumper (not near the lights) however I didn't investigate - I ran new cables from the lights to the dash and relay, fuse to the battery.
Here are some more pictures.
1. The back of the GLX old red reflector (not no globe holder) and the GX model housing with the globe holder.
2. Night shot of the two lights.
3. View from the side of the cruiser looking back.
Hey Pekka
Lights look good mate, I've searched a website and come up with part numbers 81680-60110 LH and 81670-60150 RH I then went on www.amayama.com and can buy them from UAE for $39 each.
Thanks for the link to the switches
Slick!!
~ Cal
Reviving an old thread here. These reverse lights seem like a very clean way of adding additional lights to the rear. Searching Partsoq and Amayama indicate that these are no longer available? Anyone have an idea where I could get some of these, or does anyone have a set laying around? Aus maybe?
I am also very interested, looks like a very useful project.
