A little help for a newbie
Missouri
2008 LC. Changing shocks and did not keep track of which spring is driver side and which spring is passenger side.
One spring has 3 yellow paint dots and one spring has 2 blue and 1 white paint dots.
Original springs. Can anyone with same or similar model year or tell me which spring is for which side??
Thanks for your help.
I was gonna say, the Chitown listing didn't agree with the info I got when I asked the board
yeah i posted a confirmatory thread after the hearsay post indicating an actual picture with the correct positioning.
sorry it wasn't more clear lctuff08
Kannada and Bloc
Thank you both for your help. Going to swap the springs so 3 yellow dots DS and 2 blue 1 white PS and see what happens. I will post a follow up here in about 10 days as it will be a bit until I can work on the LC again.
OK, sorry for the delay in giving follow up. I adjusted the KDSS as per some youtube I watched, it was very easy and it corrected the problem. I believe the springs are in the correct position. Thank you everyone for your help.
