I recently acquired a 1970 FJ40, with a 1972 F block and 1978 4 speed conversion..
Truck runs with no problems as it is.
Some new mechanicals including fuel pump+filter, electronic ignition, radiator recoring, new clutch master cylinder.
I would first like to replace the spark plugs, plug wires, distributor cap, and air filter. I would also like to change the oil and replace the oil filter.
When running, the choke cannot be fully pressed in without stalling..which as I understand is a carb problem.
Are my priorities in order with what I should do to ensure a strong running motor? Anything else that I am overlooking?
Also, engine parts are listed up to 9/72, and then from 9/72 later. How do I determine when my engine was built?
Thanks
Thanks
