sschruff
Make PSILOCYBIN legal for TBI/PTSD/TRA&D
- Location
- United States
So, started clearing out parts that I'm not using on my build. The following parts are being listed as a lot, meaning I'd prefer to give a discount for the lot vs having to list them individually here and on eBay. Retail value of all parts combined is +/- $2800. I'll sell the entire lot for $2000 + shipping. All parts are new, OEM Toyota, and still in original packaging, aside from two non-oem parts highlighted in orange.
Link to pictures:
Lot part numbers/description are as follows:
Parts associated with axles/hubs/brakes/driveline/etc:
42603-60052 x 2, center wheel hub caps
42137-55010 x 2, rear axle collar
90116-08325 x 12, bolt
90116-A0025 x 12, bolt, stud
90126-12005 x 16, Stud, hex lobular
90942-02052 x 12, wheel lug stud
42443-55020 x 2, brake oil gasket
91612-61040 x 4, bolt, transmission case/engine setting
90105-11013 x 12, bolt, front propeller shaft
90341-18021 x 6, drain plug
12157-10010 x 10, drain plug gasket
90201-12019 x 12, washer
90249-08068 x 2, pin
46469-60020 x 2, cable guide support, parking brake lever
47626-60010 x 2, parking brake pulley
47624-60010 x 2, parking brake crank
47628-35020 x 2, bell crank bracket
47633-35020 x 2, bell crank boot
91611-41045 x 1, clutch slave cylinder
31231-60050 x 1, hub, clutch release
04445-60030 x 1, gasket kit, power steering
16341-61030 x 1 and 16343-61010 x 1, water outlet gaskets
Bearings:
90366-35011 x 1, Bearing/RTP/35,85
90366-35053 x 1, Bearing/RTP/35,80
90363-52001-77 x 1, Release bearing
90363-15004 x 1, pilot bearing/input shaft
Parts associated with steering:
45280-60120, Hub/steering
96152-0030, snap ring/steering intermediate shaft
90521-22011, snap ring/steering main shaft
45819-22011, retainer/tilt steering
90501-45011, spring/steering
90506-23009, tension spring, tilt steering
90301-60122, O-ring, steering column
04371-10011, spider kit, steering
45260-60080, shaft, steering
Body/Interior/Exterior/Electircal:
69810/69820/69830/69840-90A01, Full set (4ea: 2ea front/2ea rear) of front/rear window regulators
53420-90A00 x 1, Hood Hinge, LH
74105-10010-01 x 1, receptacle, shadow grey
55545-90A01-03 x 1, fuse box cover, shadow grey
90987-02006, Relay
84231-28010 x 3, courtesy switch
Misc:
90101-10269 x1, bolt, cooling
90430-A0003 x 1, 18mmx24mm Alum Gasket
94512-01000 x 20, spring washer
94110-41000 x 8, nut
94110-51000 x 10, nut
Non-OEM parts:
Man-a-fre stainless, extended brake lines, full set front/rear
Marline Crawler HD Front Inner Seals x 4
Link to pictures:
Bearings:
90987-02006, Relay
Misc:
Non-OEM parts:
