Following up on a new noise on my 97 80 series here. I recently had a noise that was like a rumbling, clunking that occurred mainly at initial take off from a stop. The noise turned out to be hose clamps vibrating on the firewall. Problem was fixed but it took my mechanic several hours to figure out. In the process of diagnosing the noise, my mechanic removed the front driveshaft to see of the noise went away. Removing the drive shaft did not make the noise go away, so he reinstalled it. Fast forward to now and I’ve noticed for the last week since I’ve picked it up at the shop that it has a new noise / vibration. The noise / vibration only occurs between approx 60 and 65mph under load on the highway. It’s like a wheel out of balance feeling. I can feel the vibration in my boots through the floorboard. This vibration was not present prior to having the hose clamp noise addressed, so I don’t believe it’s a wheel balance issue. It was smooth as silk only a few weeks ago. I crawled under it to look around and noticed the front drive shaft is installed in phase - like the rear. I could have sworn it was out of phase prior to being removed and reinstalled by my mechanic. From reading through this forum, looks like it should be 90 degrees out of phase. Could being in phase cause the vibration at only a speed range of 60-65mph? I did take the truck up to 75mph then popped it in neutral and coasted down to 30mph with no vibtration observed. If this is likely the problem, how hard is it for a weekend mechanic hack like me to remove and reinstall correctly? I’m skilled enough to use a torque wrench but by no means a certified Toyota technician. Oil changes are about as far as I usually go or have time or desire to perform. And...would running the front shaft in phase be causing any damage? Muchas gracias!
