I just bought an FJ60 here in the Houston area and I'm looking at making it a good runner. The truck is a 1984 FJ60 and it is fairly good shape. I got it from a buddy of mine who had bought with the intention of fixing it up and it just sat in his garage.
The truck has the interior stripped out and I'm working on getting the floor cleaned up so I can put down some sound deadening material. The floor has this cotton like material that I guess was acting as sound deadening all over it. I'm guessing a peel and stick would work well. The truck came with some vinyl flooring so I've got it laid out on the hood of my K5 Blazer so it will flatten out a little. My plan is to get the floor cleaned up, instal some sound deadening, and then the black vinyl flooring over that in the front and back seat area. In the rear cargo area I'm planning on having Line-X sprayed.
One question I have is what is the best way to remove the transmission and transfer case gear shifter? I see that they seem to both be mounted to the same piece of metal. Do you just un-bolt them at the transmission and the transfer case, and then as one unit in the cab? I ask because the vinyl flooring I have doesn't have holes cut for anything. So I'll need to remove them so I can lay the flooring flat in the cab, mark where holes need to be cut, and then cut them outside the truck with a box cutter. I'd like it to look as close to factory as possible.
