- Thread starter
- #101
Another thing to check is the welch plug that is behind the bellhousing on the driver side of the block. It is only 1/2" - 3/4" in diameter, but will leak with the engine running. I had a steady drip from mine after the shop replaced it because they installed the plug wrong. I bring this up because you said your engine had been worked on when it was the PO's.
You will see this plug after you remove the pressure plate, clutch disc, flywheel and then the bellhousing. I would recommend taking the bellhousing off even though you don't have to when installing a rear main seal just so you can check this welch plug. Search my name and welch plug on this forum and you'll find my posts.
Thanks for the tip and I'll make sure to check it. Kind of hard to install a plug incorrectly. One way in and opposite way out. I'll check your post though.
