Two pics. First is steel brake line routed along frame rail used to transport gas from the tank forward. Second pic has the flare nut mounted to the steel line that adapted to the OEM flex hose. What I don't have a picture of is the bubble end where the EFI rubber hose attaches from the electric fuel pump. I'm running 45psi through this line.
Nice set-up pappy!
A few follow-up dumb questions..
#1
If I run 3/8 brake line with standard rubber hose transitions and standard hose clamps. I'll just use the rubber hose thru the tub and at the fuel switch and pump barbs fittings, but wondering,
what size rubber hose? I assume the steel line is a 3/8 I.D.? So I'm only using gear hose clamps, so I want it snug. The rubber would have to be at least 3/8 right? Right now, I have 5/16 rubber, and wondering if a fatter 3/8+ rubber line will be too loose at the switch and pump?
I decided against the steel braided line. I really like how Ken's looks, but the inside is still rubber. And, the steel braid line seems harder to work with, cut, and have to use those aluminum fittings. I'm going to try to keep the rubber at the transitions as short and easy-to-replace as possible.
#2
I think I'm going to try to run brake line, like pappy did here.
Right now, I have rubber line running over my rear drive shaft and close to my dual exhaust. You can sort of see this in my pics above in post #13 in this thread. I'm not sure if it was the old rubber, the bend, the vibration, the nearby heat, or all 4, which contributed to my gas leak. If I run steel line in this same course,
will the heat cause any "boiling" of the fuel and vapor lock in the steel line? I am NOT running EFI. Just a plain ol'
non-pressurized carburetor system. I can wrap the steel line in this area with this shiny heat shield puffy tape?
#3
Those 6mm brackets bolted to the frame work perfect. It looks like there is a rubber lining.
Where do you get those, or something similar?
AS ALWAYS.. MUCH THANKS!!!
