cruiser_guy
Out of Africa / North Africa
I picked up the '67 FJ45LV today and it almost made it home under it's own power. If the fan belt wouldn't have jumped off and made the truck over heat and blow the rad hose it would have made it!
I'll be doing a complete restoration on it which hopefully will include a disc axle and a 4 speed tranny. Currently the front driveshaft splines are quite sloppy so I'll need a new shaft. Is that common with '40's? The altenator is the wrong one and is causing the belt to jump off the pulleys. I assume that is the same as any other F engine. I'll post up some photos of the carb as well as they PO has an air cleaner that's about the right size for a ride on mower!
