Sweeet Jerry Jeff sticker...
Thanks Ziff. Do you have a build thread somewhere?
First order of business is getting it running. I'm itchin' to drive it before I take her apart. Problem is, I'm a newbie mechanic too. I've never messed with carbs and I think that may be my problem right now. New battery, spark plugs...It wants to crank. It just won't. Any suggestions?
I still haven't gotten it started. All the spark plugs are new but I'm not getting fire. Nor am I getting fuel to the carb. I'm going to replace the wires tonight. They're litterally falling apart. Should I go ahead and replace the dist. and rotor too? Battery is on the charger now and I found some tires that will hold air so when it does crank I can take it for a spin.
Jerry Jeff wants to sing but he's got a case of stage fright!
Wish me luck...
I doubt it ran 6 months ago then if your having that many problems. Did you check the main wire going from the coil to the distribator for spark.
I would put on a new:
Cap ordered today
Rotor ordered today
Wires ordered today
fuel filter less than 1 year old (saw recipt) change anyway?
plugs ordered today (store only had four)
(all this would be cheap insurance anyhow)
Get your battery up to charge (working on it--probably get new just because), or swap a known working one for fun.
spray a touch of starter fluid or a bit of gas in carb
Have a timing light ready to roll. don't have one yet
Double check your oil level, and pressure once it fires.
Have fun keep us posted. will do!
