New F & 2F carbs
Yay !!!! Can't wait to put mine on
PayPal sent.
Sent from my iPhone using IH8MUD
Machined all the spacers yesterday . Glad to have that done. Also shipped some carbs out as well. Have a whole bunch to inspect, test, and build. More pics to come.
PayPal sent for a carb for a 76 fj40. I am at 1,000 feet elevation. thanks, Charlie
Just ordered one for my '72 F, please let me know when it ships, thanks!
Dunno if it matters, but we're @ ~300' elevation relative to sea level.
cant wait for mine to get here ....hopefully this will get her back on the road :)
yea got my carb in the mail thanks .....should i adjust air fuel mix or jus set the idle and see how it runs??
toyofj60 said:
got any pics showing which screw is the idle speed screw?
Idle speed screw. You shouldn't need to touch the other screws. Call me if you need and help. 864-414-0563. Marshall
Thanks
what about the vac line for my bvsv for the evap system... i was using this, what should i do with it now?
can it go to my "gas filter on the intake manfold instead and still work decent>
no havent been able to figure out how to post pics yet my comp sucks!! my cruiser was setup identical to trapper50 's pics in the "my demog thread".... i was talkin about the vac line that was connected to my carb on the valve cover side and went to the bvsv on the thermostat housing from there it goes to the vsv on the inner fender, which is used to control vac to the evap canister i think ...i had three vac lines to the side of the carb previously. The vac advance, the decel fuel cut , and the bvsv for evap . the other port i had capped . i took out my fuel cut vac switch when i put on the troll hole, hooked the advance line to the carb i was wondering if i could hook the one for bvsv to the thing with three nipples on it that is on my intake manifold (the manual calls it a gas filter) to receive vac
by the way i installed the carb tonight and it fired right up, i didnt get a chance to set the idle good because my power steering pump my dad jus rebuilt for me started leaking :( but it ran long enuff for me to kno its definitely an improvement. very smooth ......hopefully i will get to drive it tomorrow maybe jus maybe the new seals in the pump have swollen and it wont leak tomorrow:)
My carb should be here Thursday. I ordered the idler pulley, cap & plug & EGR blockoff from Jim C. today. Looking forward to getting all that failing smog crap off & getting my FJ60 running good again!
drove it yesterday..... this carb is awesome new found power and runs extremely smooth very impressed thanks Marshall
