new door hardware 70 series
2fpower
lenexa, ks
I recall someone lately buying all new door hardware for their 70 series. window cranks, door handles, etc. Based on my VIN, many of these are NLA, so I went to find that thread and get part numbers; however, could not find it.
Anyone recall who that was?
BJ7309507585
04/1992 TOYOTA LAND CRUISER (BJ73LV-MPW)
specifically, window cranks was my first NLA part.
Window handles: 69260-10040-B7 (works RH and LH side) (available in US)
Get the escutcheons as well: 69266-22010-08 x2 (available in US)
RH window regulator: 69810-60330 (available in US)
LH window regulator: 69820-60300 (available in US)
RH exterior door handle: 69210-90K00 (available in US)
LH exterior door handle: 69220-90K00 (available in US)
RH inner door handle: 69205-10040-B7 (available in US)
LH inner door handle: 69206-10040-B6 (available overseas markets)
RH door lock rod with pull handle: 69603-90K00-B0 (available in overseas market)
LH door lock rod with pull handle: 69604-90K00-B0 (available in overseas market)
RH door lock assembly: 69310-60070 (available in US market)
LH door lock assembly: 69320-60070 (available in US market)
69759-30021 x2: Door lock rod silencer (available in US)
RH door lock link: 69711-90K00 (available in US)
LH door lock link: 69712-90K00 (available in US)
RH/LH vapor seals: 67831-60070 x2 (available in overseas markets)
That should be a good start for you.
Do you know the part number for black door handles or are they after market?
can you help me find a front left door window regulator for my 1984 Bj73? i will greatly appreciate it VIN BJ730000158
Its in post 4.
got it! thank you
You can use other 84-99 7* series regulator, most of those on the net are advertised as 75 series and they will be the same as yours.
it is kind of a pain. there is a metal shield (that's what I would call it) that gets in the way of the bottom part of this rod install/removal. I believe the screws holding this shield are on the side of the door under the door latch. at the bottom where this rod hooks into there is a plastic clip that has to be moved out of the way, like the one on the inside door handle. yes you have to remove the door card and some of the plastic.
Ok, is it possible to do without destroying the plastic piece inside the door?
If you pull it back slowly the goo should give, you could also try using a hair dryer to soften it up first
That is a good idea, I should have tried that but it wasn't too bad. The first time I kinda messed with it I guess I didn't pull hard enough. This time that part was easy.
New door plastic vapor barrier is something like $8 IIRC. Also you can pull on the plastic to stretch the butyl rubber and use a box cutter to cut the butyl. It will stick back to itself.
