For Sale New 12v or 24v Koito fog lights (2 Viewers)
Good comparative picture so people can see how the rectangular and circular lamps compare. These are mounted using the factory bumper bolts.
Excited to announce that we are now a Diode Dynamics dealer and can now offer a easy to install and modify (to work with our fog lamps) ready made harness! Run the switch of your choice, very easy to adapt and built to last. :cool: Snag some of our new Diode Dynamics offerings here. This is the perfect pairing with our custom fog lamps and will get you on the road sooner. :cheers:
Hello! I am considering installing the rectangle Koitos on my 100 series. Any issues I should look out for. Also, can I hook the lights up using the Diode Dynamics Light Duty Dual Output 4-Pin Offroad Wiring Harness. I am a rookie on most of these things so I apologize for the dumb questions.
Hey! No dumb questions at all. Happy to help.
Where were you thinking of mounting them on the 100? An accessory harness like the diode dynamics one is definitely needed to. It should be easy to add into the 100 and we are happy to help if you have any questions as you tackle that. A clean way to integrate a fog switch into the dash would be this route: Fog light switch, OEM look - https://forum.ih8mud.com/threads/fog-light-switch-oem-look.183764/
The Diode dynamics comes with a little round illuminated switch.
I appreciate the help! Going on a stock bumper for now. Any other things I need to look out for during install?
Definitely measure 3-4 times and drill once. :) But before you do that, try to securely mock up the lights first on the bumper and stand back and see how you like the placement. I did that a few times on my truck. Try to also pick a spot on the bumper that is sturdy. You can always add a wide fender washer or a long piece of angled aluminum that spans both lights underneath to help give more structural help on plastic bumpers. That will help reduce any shaking.
I can’t speak for the Cruiser Cult guys to say what they can make work with various harnesses, other than to say they were great to work with on 2 sets of lights!
I used a Baja Designs wiring harness and they were kind enough to build a lead that connected the 2 different types of plugs so my lights were plug x2 and play.
