Need to replace the windshield. Lots of people seem to have issues after that-- why? What should I ensure the mechanic does? (4 Viewers)
West Chester, PA
Going to use OE Toyota glass, because I can't stand the waviness of safelite/chineseium.
In terms of installation steps, what do I need to make sure happens to ensure I don't have leak/rust issues down the road?
These are notoriously hard to do correctly. "Pointers" won't cut it. The installer has to have done at least a dozen
of them to be trusted. And no handing it off to the new guy.
I'm not sure you'll find OEM glass, IIRC most go with aftermarket.
Post up in your local Clubhouse to see if there's a "go-to" guy in your neck of the woods.
Not only do they have to have actual experience, they need game plans in case they run
into one that has been done improperly in the past as it relates to side trim pieces and rivets
vs. screws, etc.
Lots of threads on the topic and several really good youtube videos on the install. Basics of it is checking for rust after removal, taking care of it if it's there, making sure new windshield has a really good seal, and that rivets are used for the side pieces, not screws.
I have a full crack from top to bottom and I’m having major anxiety about this job being done wrong. I found a shop who knows exactly how to do it but they said it’s too much work so they stopped doing them. From everything I have found the prep process is crucial. Cleaning and repairing any rust. Then the next is the rivits. Although I have read some members have had no issue with the screw type for the molding.
For folks who already have one done incorrectly with screws...
Don't people usually redrill and nutsert?
I assume that, at this point, the car is old enough that going to a Toyota/Lexus dealership for the job is not a way to have it done correctly? They don't have a TSB/procedure to follow to ensure it's done correctly?
Dealers rarely do glass. They typically sub it out.
