Need to removal a stuck harmonic balancer, how to (4 Viewers)
Perth
Need to get that off, how to do so
Use a puller?
Really, there are threaded holes in the balancer for this purpose. You'll need a plate/bar longer than the diameter of the pulleys and wide/thick enough to support the force required to remove it. 5-7.5–cm wide x 5-6–mm thick will work. You need a hole in the middle for the press rod; that one has to be tapped, or you can weld a nut on the plate. There should be two clearance holes on either side of that, in line with the tapped holes in the pulley.
Attach the plate to the pulley using two screws and thread the pusher rod into the plate against the crankshaft. Keep turning it and the balancer will slide off.
Use a puller?
I did try use the puller but it seems really stuck on there, just wanted to get some other peoples opinions
doesnt that centre ring bit with the guide and the outer sleeve part of the pulley come off?
it did have a bit of play in it after trying to use the puller the first time
Yes, a puller works great after the crankshaft/harmonic balancer bolt has been removed. Is the bolt still there?
Yeah but it's loosened off, I've been using the base of the puller off that, should the base go inside the crank bolt?
Looking at your picture, there is a large hexagonal piece(30mm) in the center of the harmonic balancer that looks like a bolt head. That bolt must be removed. Usually requires two levers about 1.5 meters in length, one attached to the harmonic balancer the other to the bolt, pushed in opposite directions to loosen enough to remove.
Yes, you have to remove the harmonic balancer retaining bolt. The puller is designed to fit into the chamfer in the threaded hole; you're not going to damage anything.
If it still won't budge, you'll have two choices:
1) » use an impact wrench on the puller; or
2) » put some heat on it. This will render the harmonic balancer unsafe for reuse, as it will degrade the rubber between the hub and the pulley.
Once the bolt is off, the balancer should just slide right off the crank. The bolt is torqued to over 300 ft./lbs. It's going to be tough to remove. Place a long 3/4" breaker bar and socket on it with a ratchet strap holding it tight against the right side frame rail. Remove the ignition coil wire and turn the key to engage (bump) the starter. Starter should break it loose. It's scary, but I've done it this way with great success. If this method doesn't appeal to you, an alternative method is to remove the flex plate inspection cover and fit a ratchet and socket onto one of the flex plate bolts. Turn the flex plate by hand until the socket jams against the bell housing. Then use a 3/4" breaker bar to break the balancer bolt loose.
