Need to loosen bent u-bolts on front springs
So. Austin, tx
I was ready to install some 4° shims I received from @orangefj45 but the two front u-bolts got bent on the rocks at the recent LSLC Roundup...
Can I heat these up and try to straighten? If I heat them up will it affect integrity of the bolts? Should I just order a new pair?
I don't think you'll get nuts to thread well if you're bending it back. I'd just cut & replace if it was mine (Or evaluate the need for a u-bolt flip).
Cut and replace and then cut the new ones close to the nut, so this doesn't happen again, or buy some U-bolt flip plates from 4Plus Products or skid plates that protect the ubolts.
Just adding concurrence.
Did quite a bit of research un U-bolts (Obviously I live an exciting life) and the smart money says U bolts should be torqued once as they stretch and weaken during the process. While thousands of people reuse/re-torque, I keep extras on hand.
just adding to the "off with their heads" side. didn't read all the replies, but i'd not be surprised if u-bolt flips were mentioned to be done. or as the the post above, u-bolt skids
