ok... first a little background... I have a '78 FJ40 and I just spent about $2300 having my transmission, t-case and clutch rebuilt.. my mechanic told me that all my tranny gears were in good shape so the rebuild consisted of all new bearings and seals, gaskets, syncros AND that $500+ ring assembly because he said he would not do the rebuild unless I replaced that too... my t-case idler gear set and high speed gear had chips in the teeth and needed to be replaced.. I bought good used gears for that and a new bearings, seals, and gasket kit... new bushings for the gears that had them were also bought and taken to a machine shop to be pressed in and machined to fit the shaft... all new aisin clutch parts... when he put everything back in, it was still up on the lift and he started it up and let it run for a while with no load.. shifted through the gears and everything seemed fine... took it down and went for a drive and he said there was an obvious whine that he thinks is coming from the t-case... I've driven it now, and the whine is very obvious and much worse than any whining that I had heard before the rebuild.. he said that everything was within specs but he thinks it might be because the used idler gear set and high speed gear came from another t-case and even though they looked to be in good condition, they were originally in another case with other gears that they were originally matched with or wearing against for however many years so they could be meshing with the others a little differently now and causing the whine... does anyone have an opinion on this issue? All I know is that I was expecting it to be quiet after spending all this money on the rebuild... and this is a very significant whining in my opinion.
Also, when he drove it, he was shifting through the gears and shifting into 4wd and said it will shift into 4 wheel low and high fine but then will not shift back out ... he put it back up on the lift and it will shift out of 4wd fine.. shifts in and out of 4wd fine on the lift with no weight on it but if it's on the ground it will not shift back out of 4wd... he says that he thinks something is binding the front driveshaft at the front differential... has anyone ever heard of this problem ? any ideas ?
Also, this probably sounds bad, but due to a lot of different factors, mainly not having money to fix broken stuff and not having time to go 4 wheeling anywhere, I had not even had it in 4wd in over 2 years before I took it to him for the rebuild so I don't know if this was a problem before the rebuild or not.. I used the 4wd over 2 years ago when it last snowed here (in Georgia) and it shifted in and out fine then... any advice or opinions would be appreciated.
