Need PN for 11mm Driveline Studs in Parking Drum
Havn't had time to track this down and need to get my 1350 flange to the machine shop to have it drilled for 11mm studs (could do myself, but need some other maching done as well). Same as what would normally be on the rear of late 70's FJ40 parking break drum on the t-case, except that I'm going to be running Jessie's 32 spline 1350 flange and parking brake....
Any ideas?
I'm not sure if this is exactly what you are asking for, but OEM parking brake driveline bolts (1974-2000) are:
90114-11124
HTH.
90114-11124
HTH.
Thanks! That helps - at least I have better name to describe them than what I was using :hillbilly:.
In the fiche, they are actually listed as "bolt, serration" in the parking brake section.
theres only two options may as well have both #'s
69/03-74/01
#90114-10007
74/01-80/07
#90114-11124
HTH.
Like Poser said - went with first PN as it matched years for 11mm stuff. Hate it when I can't drive to my dealer with the discount - full Toyo retail is $4 apiece - stoopid as if I had more time could just pull one and go to NAPA. Oh well. Such is life.
Also used a 91 4x4 4-runner as a reference to order rear 10mm driveshaft bolts. Hoping I got that one right.
Thanks.
Hi all,
I happen to have a set of the parking brake drum studs for mid to late 1970s era 40 Series out in the garage. Purchased these from Spector Off Road (SOR) several months ago.
The SOR part # is 076-16C/068-78. The label also lists a Toyota OE part # of: 90114-11124.
Regards,
Alan
90114-11124
HTH.
90170-11205 - same as the other driveshaft nuts. Washers, same thing - 90206-11085.
